well theres your problem. broke the input shaft
It never changed
Check line pressure. Pull the plug next to the spin on filter, put a good sized pan under the hole where you removed the pressure plug. Start engine in park, and rev it to about 2,000 rpm for a couple of seconds. Fluid should gush out. Shut off engine right away. If you don't get a gusher, your pump is hurt.
Time for a billet shaft.![]()
Has anyone had an input failure at speed? I'd figure it'd happen at a dig with a shock load. I guess if you exceed its strength with torque it's apt to bow out.
What torque are they typically "safe" to?
Knock on wood I have stock shafts in my trans :roflmao:
How many miles are on your truck OP?
Hey everyone im having this identical problem. Like exactly,and i cant seem to find the right pids to monitor input and output speed and turbine speed on efi live scan tool. Im thinking broken input but i hope not. This trans was in matt misners race truck and supposedly held very high hp. But does have the stockers in it
