baddaddition
Mar 10, 2013
287
Sent from my XT1254 using Tapatalk
8,238
Limos been sleeping for a month so on the way back from discount tire I rang her out a bit on the tow tune
http://youtu.be/GdCoTLGyJwg
It's the big hammer hard swing mod, with some cutting... Clears 285/55/20 on 20x12 -44 wheels with no torsion bolts whatsoever.
I pie cut the rocker on mine, folded it back and welded it back in. Then shaved the pinch seem, welded it and ground smooth.
Before
After
Trimmed the fiberglass fender after the pic.
Before
After
Looks great
1,514
Drugged this 7x8x20' 9500lb box up and down a shit ton of grades including 13 mile 6% lots of 5% and less, several 7% had me down in 3rd gear at 2500rpm climbing out of Cumberland md on a humid 90° day
minerigger
2,660
Casper, WY
Shift cable linkage broke off the rod on the side of the transmission. Luckily it was in park and I was at home when the lever fell back down. So to figure out how to replace tomorrow.
Gone for 4.5 weeks and I come home and this is how she treats me
Henry95
283
I pulled a loaded gravel truck down some hilly back roads. It was about 32 tons! Hope that isn't the reason it is sitting in gm's shop with a wiring problem for the oil pressure sensor as she got really HOT.
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
I got a set of Recon LED tails!!!
I've wanted these damn things for almost a decade...LOL
Glad I waited tho, damn things were like $700 back in the day, but got them delivered for $300
:thumb:
rgullett83
1,607
Illinois
Welded in pieces on the end of the new steel lower valance where I had to cut it, to make it look factory again. Then took it back to body shop for repaint
