1/4 mile discussion and time slips post here!
IdahoRob
Jun 5, 2007
1,151
Ken can you update my MPH please.....I'm hoping to move up the list more Wednesday night if the weather holds. Thanks
Great 10.50 index run.
Number 25 would put you in cert'd cage/license/safety requirements along with the HP for very high 130MPH unless killer 60's. Good luck!
smkndmax05
"Smoked Out"
Feb 17, 2011
479
Indiana
I learned the hard way at TS. I went 10.43 letting out at the 1000 ft mark with a 1.52 60'. 2000 pulse on 100 overs. I went 10.26 with a speed limiter at 131 about a month ago on a 2200 shot.... Brayden has worked hard to get all the bugs out so we are hoping its close! The truck has cut numerous mid 1.4 60' so that's a plus. My cage will be finished and my safety equipment is all rated for the 9s along with my NHRA paperwork filled out. Thanks for all the info Rob!
rfletes79
656
196
Galt, Ca 95632
I wouldn't mind running 10.20's in a stock piston LBZ, that actually may be the fastest stock pistons ever :spit:
We went a 9.7 with stock Pistons in my Chevelle, same weight as that truck. It was a motor that Russ built from Rpm Motorsports. Put about 100 passes on them before they started letting loose. LB7 pistons.
IdahoRob
Jun 5, 2007
1,151
Sweet, I hope you meet your goals. We need more fast Duramaxes as the Sharks(Cummins) are circling...
RPM Motorsports
smokinum
May 13, 2008
3,271
10
Central Valley Ca.
Can you update our MPH when there are others Ken. Track wasn't there, and pretty much like a no prep race. Ponci was running 152's and the same ET as well.
Subman
Old Geezer
Jun 27, 2008
3,233
10
81
Madras, OR, Pahrump NV
1.Banks Dragster 7.170 @ 181.08 (4-30-09) - 2290 lbs, Liberty XT5/Molinari Clutch - BANKS
2.NGM Diesel Prostock 7.44 @ 187.55 (6-1-13) - 2800 lbs, turbo400 - Johnboy
3.J.Dean's Dragster 7.64 (6-8-13) @ 170.41 (10-13-12) - 2100 lbs, LBZ, powerglide - Stingpuller.
4.Banks Sidewinder Type-D Prostock 7.723 @ 179.23 (3-29-08) - Liberty XT5/Bruno - BANKS
5.NX dragster 7.829 @ 172.08 (6-11-11) - LBZ, Powerglide - Johnboy
6.Batmobile prostock 8.286 @ 177.23 (4-11-15) - 2700 - LBZ,Bruno/Lenco - Milliken
7.Dirtymax prostock 8.63 (6-16-12) @ 158.23 (5-19-12) - 3268 lbs, LB7, Lenco - ATP
8.bcdeutch731 C-10 8.810 (10-4-14) @ 158.33 (9-25-14) - 4540 lbs, LLY, T-400, 2x4 - DP
9.RPM Motorsports 73 Nova 9.150 (10-26-14) @ 155.49(6-6-15) - 3460 lbs, LBZ XP 5 Glide, ATP
10.NX Mustang 9.216 @ 154.5 (9-18-10) 3600 lbs, LB7, 4L80 - Johnboy
11.N20 Dmax 9.24 @ 151.6 (10-20-13) 5900 lbs - LB7, Duraflite - TTS
12.Max'd Out 9.360 (10-15-11) @ 152.37 (5-30-15) - 6050 lbs, LBZ, Duraflite - ATP
13.W Minter 9.370 (3-22-14) @150.20 (5-30-15) - 6005 lbs, LBZ Stroker, Durflite - ATP
14.K Douglas C-10 9.393 @ 147.46 (10-4-14) - 3100 lbs, LBZ - 2x4 - G&J
15.Overkill 9.50 (6-23-12) @ 153.30 (7-29-13) - 5950 lbs, LB7 - Dmitri
16.J&R Auto GMC 9.570 @ 144.76 (8-11-12) - 5950 lbs, LB7, stroker, Duraflite, J & R
17.Brett Williams 9.688 @ 147.10 (6-14-14)- Lb7 - Starlite
18.Mad Max/Hell Camino prostock 9.68 @ 149.1 (8-10-13) -3600 Lbs, LBZ, duraflite- ATP
19.Mike Graves 9.735 @ 145.17 (10-24-14) - 6920 lbs, LB7- MOONSHINE
20.cafryer 9.769 @ 145.02 (8-16-14) - 6500 lbs, LB7 - Duraflite- Starlite
21.Dallas@Suncoast 9.778 (6-11-11) @ 139.33 (5-18-12) - 6300 Lbs, LBZ, Duraflite
22.Rick Fletes/RPM MotorSports 9.78 (8-17-13) @ 142.4 (6-29-13) - 4530 lbs, LBZ Chevelle, XP-5 PG -ATP
23.Extreme Prejudice 9.87 (7-10-10) @ 146.13 (5-15-10) - LB7 - EPR
24.Orange Crush 9.875 @ 139.41 -(9-25-07) - LB7, 2x4 - TTS
25.Mika 9.897 (8-29-10) @ 138.70 (8-14-10) - 7160 lbs, LB7, Duraflite - BOBO
26.Camomax 9.91 (2-25-12) @ 139.36 (11-19-11) - 6150 lbs LB7 - Duraflite, ATP
27.Dan PPE 9.947 @ 142.04 (11-1-14) -6200- LLY - PPE
28.Duramini2001 9.994 (8-13-11) @ 138.566 (5-15-10) - 6700 lbs, LB7 - Dmitri
29.Misery 10.01 @ 144.52 (10-4-14) - 6000 lbs, LB7 - PPEI
30.estelly 10.13 (5-18-12), 140.05 (4-15-12)- 6140 lbs, LMM - PPEI
31.Jim Jones 10.148 @ 140.52 (10-13-12) - 6150 lbs, LB7 - ATP
32.OSUBeaver 10.184 (8-13-11) @ 134.59 (5-21-11) -5997 lbs, LB7, Duraflite - ATP
33.SmoknDmax05 10.269 (4-18-15) @ 130.59 (5-30-15) - 6400 lbs, LLY - Fleece
34.MorePower 10.271 @ 133.39 (7-13-13) - 6820 lbs, LB7 - DP
35.TDS Miami Colorado 10.281 @ 137.72 (4-25-15) - 4550 lbs, LBZ - Duramax Tuner
36.NolanW 10.285 @ 133.15 (8-11-12) - Duraflite - ATP
37.Sweetdiesel 10.286 @ 144.09 (9-3-10) - 5700 lbs, LB7 - Simon
38.Custom Auto shop truck 10.34 @ 140 (8-25-12) - LB7 - Custom Auto
39.Nasty Girl 10.355 @ 131.11 (7-13-08) - LB7 - MOONSHINE
40.Sickdiesel 10.429 @ 134.00 (4-6-14) - 6450 lbs, LBZ - ATP
41.BadDmax 10.438 @ 132.31 (7-10-09) - LB7 - MOONSHINE
42.MaxPowerLB7 10.47 @ 132.0 (3-11-11) - 6460 lbs, LB7 -Trent
43.Stingpuller 10.47 @ 131.75 (7-18-09) - 6000lbs, LBZ - Stingpuller
44.Alligator Performance 10.490 @ 132.78 (10-27-13) LBZ - PPEI
45.UDP 10.506 @ 137.71 (6-1-12) 6700 lbs, LB7 - UDP-mike
46.Trojan366 10.522 @ 132.62 (9-13-14) - 6860, LLY - DP
47.Dmax Tuner 10.546 @ 131.15 (9-17-14) - 5500 lbs, LB7 - Dmax Tuner
48.Hondarider 552 10.578 @ 133.88(4-6-14) - 5400 lbs, LB7- PPEI
49.Casper 10.59 @ 128 (10-26-07) - 6420 lbs, LLY - McRat
50.BLKLMM 10.625 @ 134.34 (3-22-14) - 7000, LMM - PPEI
51.CaptPhil 10.672 @ 132.62 (4-24-15) - ?, LLY -
52.GMtech07 10.682 @ 129.59 (4-28-14) - 6300 lbs, LB7 - PPEI
53.White Out 10.703 @ 130.39 (8-27-10) - 6650 lbs, LBZ - ATP
54.Rhall 10.72 @ 128.0 (8-15-09) - LB7 - ATP
55.02Bigstrokin 10.732 @ 129.59 (9-8-10) - LB7 - MOONSHINE
56.Jpowel29 10.778 @ 125.56 (10-25-14) - LBZ- JPowel
57.Othrgrl 10.74 @ 135.94 (6-19-10) -6800 lbs, LLY - DA
58.straightpiperoar 10.78 @ 127.37 (6-15-12) - LBZ - ATP
59.Big Bird 10.82 (10-10-10) @ 129 (8-14-10) - 7200 lbs, LB7
60.NLDP 10.85 @ 123.35 (6-24-06) - LB7 - TTS
61.The Dumpster 10.868 @ 124.82 (4-12-14) - 5320 lbs, LBZ - 4L85E - 2x4 - Van-JoshH
62.Bluessmax 10.878 @ 128.31 (7-21-12) - 5650 lbs, LBZ - 2x4 - PPEI
63.Maxpower91 [email protected] (10-27 -12) - 6900 lbs, LB7- Duramaxtuner
64.White Lightning 10.96(5-18-13) @ 127.76 (6-8-13) - 5850 lbs, LBZ- DP
65.J&R Auto Chev 10.973 (8-14-10) @ 126.15 - J&R
66.Utahski 10.979 @ 125.55 (10-5-12) 6900 lbs, LLY - EPR
__________________
RPM Motorsports
smokinum
May 13, 2008
3,271
10
Central Valley Ca.
That 1/8 is pretty wild mph for the ET
The car was all over the place, literally breaking the tires loose chirping all the way down the track, it was pretty nuts. Can't wait till it cools off around here so I can turn it up. We put it on the trailer right after I made a few lic passes, I think it was 108deg that day. Hopefully they put a bunch of glue down in Woodburn on the 11th for the NHRDA event :) . Thx
Subman
Old Geezer
Jun 27, 2008
3,233
10
81
Raced Woodburn this last weekend, DA was from around 700 in the morning to 2300 in the late afternoon. Weather was suppose to be 100+ but was about 20 degree shy of that due to the cloud cover. Humidity was pretty high around 60% but the track was great, smooth and you could hook great.
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
Any information on it, weight, engine (LB?) tranny tuner?
the sandrail is a LBZ with a 72mm Danville charger, 100% s&s injectors, a stroker pump, nitrous and Duramax Tuner tuning and weight is 2000lbs
Subman
Old Geezer
Jun 27, 2008
3,233
10
81
17.Merchant's Sandrail 9.62 @ 138.90 (6-27-15) - 2000 lbs, LBZ - Dmax Tuner
18.Brett Williams 9.688 @ 147.10 (6-14-14)- Lb7 - Starlite
19.Mad Max/Hell Camino prostock 9.68 @ 149.1 (8-10-13) -3600 Lbs, LBZ, duraflite- ATP
20.Mike Graves 9.735 @ 145.17 (10-24-14) - 6920 lbs, LB7- MOONSHINE
21.cafryer 9.769 @ 145.02 (8-16-14) - 6500 lbs, LB7 - Duraflite- Starlite
22.Dallas@Suncoast 9.778 (6-11-11) @ 139.33 (5-18-12) - 6300 Lbs, LBZ, Duraflite
23.Rick Fletes/RPM MotorSports 9.78 (8-17-13) @ 142.4 (6-29-13) - 4530 lbs, LBZ Chevelle, XP-5 PG -ATP
24.Extreme Prejudice 9.87 (7-10-10) @ 146.13 (5-15-10) - LB7 - EPR
25.Orange Crush 9.875 @ 139.41 -(9-25-07) - LB7, 2x4 - TTS
26.Mika 9.897 (8-29-10) @ 138.70 (8-14-10) - 7160 lbs, LB7, Duraflite - BOBO
27.Camomax 9.91 (2-25-12) @ 139.36 (11-19-11) - 6150 lbs LB7 - Duraflite, ATP
28.Dan PPE 9.947 @ 142.04 (11-1-14) -6200- LLY - PPE
29.Duramini2001 9.994 (8-13-11) @ 138.566 (5-15-10) - 6700 lbs, LB7 - Dmitri
30.Misery 10.01 @ 144.52 (10-4-14) - 6000 lbs, LB7 - PPEI
31.estelly 10.13 (5-18-12), 140.05 (4-15-12)- 6140 lbs, LMM - PPEI
32.Jim Jones 10.148 @ 140.52 (10-13-12) - 6150 lbs, LB7 - ATP
33.OSUBeaver 10.184 (8-13-11) @ 134.59 (5-21-11) -5997 lbs, LB7, Duraflite - ATP
34.SmoknDmax05 10.269 (4-18-15) @ 130.59 (5-30-15) - 6400 lbs, LLY - Fleece
35.MorePower 10.271 @ 133.39 (7-13-13) - 6820 lbs, LB7 - DP
36.TDS Miami Colorado 10.281 @ 137.72 (4-25-15) - 4550 lbs, LBZ - Duramax Tuner
37.NolanW 10.285 @ 133.15 (8-11-12) - Duraflite - ATP
38.Sweetdiesel 10.286 @ 144.09 (9-3-10) - 5700 lbs, LB7 - Simon
39.Custom Auto shop truck 10.34 @ 140 (8-25-12) - LB7 - Custom Auto
40.Nasty Girl 10.355 @ 131.11 (7-13-08) - LB7 - MOONSHINE
41.Sickdiesel 10.429 @ 134.00 (4-6-14) - 6450 lbs, LBZ - ATP
42.BadDmax 10.438 @ 132.31 (7-10-09) - LB7 - MOONSHINE
43.MaxPowerLB7 10.47 @ 132.0 (3-11-11) - 6460 lbs, LB7 -Trent
44.Stingpuller 10.47 @ 131.75 (7-18-09) - 6000lbs, LBZ - Stingpuller
45.Alligator Performance 10.490 @ 132.78 (10-27-13) LBZ - PPEI
46.UDP 10.506 @ 137.71 (6-1-12) 6700 lbs, LB7 - UDP-mike
47.Trojan366 10.522 @ 132.62 (9-13-14) - 6860, LLY - DP
48.Dmax Tuner 10.546 @ 131.15 (9-17-14) - 5500 lbs, LB7 - Dmax Tuner
49.Hondarider 552 10.578 @ 133.88(4-6-14) - 5400 lbs, LB7- PPEI
50.Casper 10.59 @ 128 (10-26-07) - 6420 lbs, LLY - McRat
51.BLKLMM 10.625 @ 134.34 (3-22-14) - 7000, LMM - PPEI
52.CaptPhil 10.672 @ 132.62 (4-24-15) - ?, LLY -
53.GMtech07 10.682 @ 129.59 (4-28-14) - 6300 lbs, LB7 - PPEI
54.White Out 10.703 @ 130.39 (8-27-10) - 6650 lbs, LBZ - ATP
55.Rhall 10.72 @ 128.0 (8-15-09) - LB7 - ATP
56.02Bigstrokin 10.732 @ 129.59 (9-8-10) - LB7 - MOONSHINE
57.Jpowel29 10.778 @ 125.56 (10-25-14) - LBZ- JPowel
58.Othrgrl 10.74 @ 135.94 (6-19-10) -6800 lbs, LLY - DA
59.straightpiperoar 10.78 @ 127.37 (6-15-12) - LBZ - ATP
60.Big Bird 10.82 (10-10-10) @ 129 (8-14-10) - 7200 lbs, LB7
61.NLDP 10.85 @ 123.35 (6-24-06) - LB7 - TTS
62.The Dumpster 10.868 @ 124.82 (4-12-14) - 5320 lbs, LBZ - 4L85E - 2x4 - Van-JoshH
63.Bluessmax 10.878 @ 128.31 (7-21-12) - 5650 lbs, LBZ - 2x4 - PPEI
64.Maxpower91 [email protected] (10-27 -12) - 6900 lbs, LB7- Duramaxtuner
65.White Lightning 10.96(5-18-13) @ 127.76 (6-8-13) - 5850 lbs, LBZ- DP
66.J&R Auto Chev 10.973 (8-14-10) @ 126.15 - J&R
67.Utahski 10.979 @ 125.55 (10-5-12) 6900 lbs, LLY - EPR
