Just finished rebuilding my 5 speed with gmax5 kit with reybestos clutches, mikes pressure spring two shims, mikes valve body springs, new valve body, new NSBU, and grinded a little on my converter valve for no knock down. ( I grinded a small amount being I have transgo parts in it) when I pulled it out the spacer had marks on it like it was banging around a little against the pin. The truck overheats no matter what. I can start it and let it sit for about 45min and temp gets up to 200*. Drive it down the road on a cold start gets up to 250*. I read that early transgo kits made the wrong size spacer causing overheating but what I read was it only did it while driving and would cool down when in park. Any ideas?
