Different Master Brake Cylinder?
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
Has anyone replaced there stock master cylinder with a bigger one? My current one is on its way out and I was thinking of replacing it with a bigger one that will have more pressure.
skintback
Take this one to church
Mar 5, 2007
926
Florida
Not sure on the master cyl but a lmm 07.5-10 hydro booster has a much better padel than 01-07 model
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
I recall Ben saying he put in an lml hydrobooster and if I remember correctly he said it was direct bolt in I'll see if I can dig up the thread.
Awenta
4,090
I think the lmm pump is better and a direct swap as well. Not 100% sure though
Dallas S
496
Alberta
Ben any more info on this? If I recall you had spent some time getting a better peddle feel outa the gmt800's. 2011 hydro boost the best choice still?
skintback
Mar 5, 2007
926
Florida
The lmm hydro booster has been a direct swap for me and works much better than what came with the truck. Not sure on the lml ones may have to give it a try one day
1,456
My GM455(99 C3500HD) chassis had a 40mm bore vs the 36mm bore my lmm has
The part number for said MC nm2754 via Autozone
Though it also has dual 66mm piston caliper and 14" disc brakes..
V
Haven't had time to look closely at either yet.. But plan on doing so
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
If this makes the brakes more like the LML it will be worth it. I go from my 11 back to my 05 and feel like I'm pushing twice as hard to stop or to hold it at a stop light. I wonder if the larger rotors had something to do with that but maybe it is just the HB.
1,456
I just flushed the power steering system. Definitely helped in pedal feel/response.. And pedal travel is less to get same respond out of the truck braking wise.. Just the flush.. Haven't messes with MC
