minerigger
2,660
Casper, WY
Oooo that's a fancy little hole Adam. If you need a set of pistons I've got a full set of lly pistons in good shape I can wrap and send out
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
#8
Damn Adam, sorry to see that...:(
Interesting fact tho, when my engine failed it was the number 8 cyl with an identical hole in the exact same spot...
divemonster
Sep 12, 2014
105
Put in 2 9 inch light bars behind the grill
Took off factory running boards
And installed n-fabs
Also changed the fuel filter but no pics of that
2007 classic duramax CCSB with
Automatic 6 speed Allison
1,457
Melted hole? On my phone can barely see
Either way bummer man :(
Yes #8
Thanks for the offer.. Going to guess they are std bore.. Thus won't work :( most likely be boring .040 over
Did #4 last time in another truck at halve the HP
Made thread for it..
http://www.duramaxdiesels.com/forum/showthread.php?t=65650
8,059
Stuck on the side of i70 700 miles from home cause a wheel bearing let loose. Waitin on a tow truck to get me into a town so I can buy a new wheel bearing and fix it.
1,457
What makes you think you'll have to bore it out, adam? Did it score the cylinder that much ?
.020 didn't clean out the last one 100%.. Basically I don't have to wait or the machine shop to figure out how deep it is.. To order pistons.... They can bore it .030-.035 over then finish up the last with a hone.. In long run its 1-2 days less I'm down waiting...
Idk how this is going to turn out.. But at least it will clean easier
56taskforce
1,096
80
Good thinking Adam sorry about your misfortune good to see you are getting it taken care of though.
1,457
17.5:1 .040 finger bowls.. Order should go in tomorrow according to larry at Danville. Got bearings, seals/gaskets to pick up and need to get assorted o rings that ripped replaced.
Need to pull the heads a part and check them.. Clean the deck up and run a straight edge on then
