My oil filter is remote mount. Sensor is in the hot oil straight from the pan
Very surprised you had troubles at those temps.
I try to keep it 220-230.. Obviously I need bigger coolers hills/long grades are 230-240
He said 235* for 600 miles that's pretty hot for a long time...
Especially with cardboard pistons![]()
That temp PRE cooler is non issue.
What sensor are you running? A thermocouple?
So you're probably looking at what, post cooler temperatures at 10 - 20 deg or so less than that? If so that's not unreasonable at all.I try to keep it 220-230.. Obviously I need bigger coolers hills/long grades are 230-240
No that ain't hot at all. Running a consistant 250-260* is pretty hot. You will run 230* temps without an after market cooler, load on the back and the middle of the summer here in AZ just on flat ground.
In the summer I run about 240* up all the hills for miles at a time, usually turning 2600-2800rpm. That was before gearing and cooling stack cleaning though.
Hitting 260-270 for long on reg dyno oil will cook it and it's no longer any good. Synthetic is best for high temps. Your generally good to about 300* with that.
Well that's where I worry. Ive seen 240 many times in 50* weather what would my temps be in 100* weather
So you say these temps aren't hot but they could still be cooler
Fingers pistons 17.5:1 or 18:1bore/balance. If everything else is in spec..Talked to several machine shops.. Got one lined up... Will have a partial short block to drop off come Tuesday morningSo you're probably looking at what, post cooler temperatures at 10 - 20 deg or so less than that? If so that's not unreasonable at all.
I think you have lots of cooling and just became another victim of a stock LMM piston. Time for a mild build.
What I found is that oil temp vs egt aren't linked.
High engine rpm oil temp roses egt drops
Low engine rpm oil temp drops egt rises.
Any dmax pulling more than 5000lbs needs some help in oil cooling. The killer bee kit I had on my gmc that james has now cured every low oil pressure issue I had while towing.
Lol they would NOT be good.
Yes they can always be cooler to a point. I just wouldn't be worried at 220-230 by any means. 260 is my cut off point even when I'm running syn oil. Generally when my oil is that hot though, my coolant is 230-240. The new fan should really help that though cause my fan was not staying fully locked the last year or two when towing in the summer
