If I'm correct the 6.7 rod is not only longer but much thinner that the 6.0 rod.
why ask him he has never done it and got the idea from us......
Or you got the idea's from me when you took Dan's perfectly running engine I built out of his truck and took it apart to look. Then proceeded to build him 2 piles of trash that blew up in the first days of use.
I suppose a great idea is all in the perspective of it. I didn't think picking 2 stock pieces out of a scrap pile, holding them side by side, and then doing some machine work was an act of genius!
This is not the way to start your comeback. You have already managed to piss off a mod. No it's not me as I get pissed off at the sight of your name. Try and contribute with actual facts.
What I stated are facts Mike. Anyone can research them and see the results from the dpc last year and other threads on other sites. I should be able to defend myself when attacked by other members.
I will take your advice here and do my best to ignore pot shots from other guys including you Mike.
That motor blew up because it overheated.... maybe if a certain shop had put the entire fan shroud in so it could cool the motor efficiently while making nitrous passes down the freeway to 110mph. I believe I still have a picture of what your turbo setup looked like on Dans truck when he got it back from you before going to another shop
that motor was disassembled last week, not that its any of your business.....
also we only built him one motor that he was making back to back nitrous passes on the highway on a 2500us tune with 100% injectors..... big surprise it didnt last.
I worked at MPD when i took one of CFD kits off a truck and sent it direct back to get a refund and had put one of their kits on. I remember the amounts of grey silicone used on the turbo pedastal plate instead of just getting the $5 base gasket from ford. Bolts were cross threaded into the head. And the manifolds leaked terrible. I personally dont think anyone wants to steal that workmanship from you.
One a side note: I no longer work there or represent them :thumb:
Jeff put that kit on himself not me logan. And he left 2 s300 compressor cover bolts that were hard to get to off. that meant 2 1/4" holes for boost to leak. So yes it was laggy and yes you guys sold him your kit. I woulda just put the bolts in for the guy but to each is own.
You did a great job on those 6 liters for norris ford lol probably why you no longer work there?
fixed it.opcorn:
