35,000.00 range, steel would be mid 25,000. Its ~800lbs heavier than my steel trailer and 5' longer ~6500 to 7300 of the crossman
Its literally a Step deck semi trailer designed to go behind a pickup
Meow! I guess it's worth it when you make a living with it. I thought average steel goosenecks were high enough.
Awesome trailer though. I'm assuming it bumped up your gross capacity?
1,517
The owner of crossman trailer retired from the R&D department building these
http://www.wilsontrailer.com/trailers/premier/drop_deck/index.php
14" neck and 19" mains bolted with hot dipped galvanized steel and Huck fasteners
At 36,000lb gross I can put ~21,000 on the deck of the trailer.. Most guys I talk to are lucky to get 17,000 on deck
Its easy 2x the trailer that runs a 12" 22ppf steel beams steel trailer be 3-4000lbs heavier
Working on cleaning the engine bay, and adding sound mat to the firewall. I'll post pics when finished. It's beer time
Here's a before
Finished my engine bay cleaning and sound mat install. Not that's out of the way maybe I can get the engine stuck in next week.
Progress pics-
Mar 28, 2015
267
Blue Springs, MO
I bought wheels and tires on craigslist. It was raining and I was too stupid to inspect them. One wheel had a janky weld job on it to "repair" a crack. The weld started leaking air. The wheels are discontinued....... ANYWAYS I picked up a set of Hummer wheels yesterday that some guy only had on his Hummer for one day, then boxed them up and stored them in his shop! Other than that, I have to figure out the best way to deal with rocker panel/cab corner rust.
cdbright
JUST RENT IT
Dec 16, 2008
1,016
Salt Lake City, UT
i ordered boost,egt,fuel rail pres gauges, and a S&B intake, gona chase down every UPS guy i see near my house for the next week :woott::woott::woott::woott:
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,374
9
Berthoud, CO
Truck ran a personal best of the slowest ET and the fastest mph haha. 15.1 @ 115mph. Either I'm restalling the converter again or swapping my high pressure charger for a different brand.
