OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
20x9.5 and I think I read somewhere they were either +18 or +24 but I cannot confirm
I got 2" adapters for the rear so they will match up a little better
rmallen30
861
15
hillsboro ohio
Pulled my stock turbo bc two up pipe bolts broke off in it, so ordered up another Danville 3794 to go back on. Also put a MA water pump on. Then I put my new lowering springs on the new diesel cruze nothing to drastic just made it a little lower
1,457
Been working on V3.0 of my oil cooler. Same fans 10" 1000cfm and same 11x11x1.5 b&m coolers I've been running.. Fans are ~1" off the coolers now.. Should put a lot more of the cooler under negative pressure
Forgot to add this... V2.0
divemonster
Sep 12, 2014
105
Added in some auxiliary lights under the back bumper. Have a 3 way toggle for on-off-auto with reverse
Just reverse
All on
Just auxiliary lights
I also tinted my cab lights along with my third break light and the auxiliary lights
Before
After
Before
After
You can't really tell it from the angle but the way the top half of the bottom light looks is how they both look across the whole lens
2007 classic duramax CCSB with
Automatic 6 speed Allison
