Who makes a complete grille for a 2006 GMC?
13,862
966
I can't seem to find anything except the center part. Does anyone make a complete replacement grille?
S Phinney
4,008
Quncy, Fl
Oem and I purchased a almost complete grill. You had to cut the lower black part off of the existing and the new one had tabs that you put the cut off piece on and melted to hold it in place. I forget where I purchased it but I recently went back to a Oem grill since the tabs broke on the aftermarket one. I would recommend just cutting your center out and replacing g with a insert if you are looking for something more appealing to you. That is basically what I got in the aftermarket one anyway but it wasn't as durable as the Oem.
lb7gmc
Feb 26, 2015
25
Alabama
Ok so now my question @s Phinney is the fuel grill from fuel off road is it the same concept ? i got to melt and shit like that into it? because my center piece of the grill is broken but all the chrome is good and i was gonna sand and take off and have paint matched but i wanted this grill and i thought i would just take out the middle insert and swap this in!
c5fourj
Occasionally moving quick
Dec 20, 2014
307
Brighton, CO
I'm in the middle of this right now, you can't sand off the chrome you can peel it but it won't sand off, I bought an after market complete grill from Amazon be careful the 2500 hd is twice as much as the half ton cause of the extra black trim below the grill surround
S Phinney
4,008
Quncy, Fl
If the center section is the same size as to fit your center section then I am pretty sure you can fit it. Attachment brackets would be your obstacle them.
Aug 3, 2013
898
Arizona
Thats probably like 600 bucks just because the fuel emplem is on there :rolleyes:
lb7gmc
Feb 26, 2015
25
Alabama
heres closer to what i would like to do, from what ive looked up and can tell is that you have to cut the old grill out and replace by drilling these ones in?
207954d1383082557-mesh-grill-installed-looks-mean-imageuploadedbyag-free1383082553.254623.jpg
