Got these 6+4 spring swapped into night.. OEM was 6+1.. They definitely had a "W" going on.. New ones should handle the added pin weight with new trailer that is coming in a month or so
I saw a hotshot rig the other day with a drop axle. First I ever seen anything like it.
The OEM handle the weight decently until you got on a rough road.. These 6+4 came off an 08 dmax C&C truck.. Rear of the truck is up about 1" vs old onesWent to cooper HT3 to replace AT3 coopers. Replaced inner steel wheels. Ordered 10k bags to replace the 5k bags.
Moved water tanks around on the trailer to help control pin weight. Ended up getting 1100 pounds nearly off the pin.
Oh and hit a tree with a low limb with the big 48' trailer.... So its back at the dealer getting the roof racks replaced and roof skin repaired.
Adam u need airbags if you are lookin at springs that size man
Converted my truck to electric.:roflmao:
Started installing my Danville 3794 I purchased from allseasondieselperformance
On Black Friday on my 07 lmm. It's been a couple years since I have removed a stock turbo, but quickly remembered how bad they suck.
3hr is impressive cocoal
Spent the afternoon taking stuff off my truck in prep for trade. Raised it back to leveled height and aligned it. I already miss how it used to drive
Before -![]()
Now -![]()
