S475 TCT single
CarolinaHD
969
NC
Ok whole piston was in the oil pan. By that I mean piston gravel. Twisted bent rod, valves were in the pan I guess, smashed injector, with no piston, the wrist pin hammered through the block into the cooling passage. Piston parts in the intake, plus don't forget it got my turbo to. It needs everything basically.
:eek: Damnit hate to hear that man. You already know what someone is gonna ask.. Any pictures?
edit: nvm you read my mind
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
picture.php
Out of room in my album but here's this
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
This engine never made any odd noises?? Went from some white smoke out of the exhaust and a turbo shutter to a completely destroyed engine? :confused:
zf>allison
Apr 30, 2013
3,394
elsberry mo
We were talking about that tonight. I never in a million years would have guessed that this kind of catastrophic damage was in the engine. I drove it on the trailer and ordered an oil return line that night, i thought it popped that. so that tells u something
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
I'm baffled how the engine didn't sound absolutely horrible. My buddy blew a hole in his piston at the track and the truck ran absolutely terrible. Shaking and sputtering like crazy when we put it on the trailer. All it had was a little hole in the piston...you don't even have a piston :roflmao:
DMAX497
Sep 27, 2012
398
Utah
I'm dumb founded how you didn't hear anything :confused:
Weird!
When Caden pulled his truck around to pits we knew instantly she was hurt.
zf>allison
Apr 30, 2013
3,394
elsberry mo
I guess maybe it had no way to build compression to make a whoosh like through a small hole. I just idled it up on the trailer. I wish I had a video of loading it. I'm absolutely baffled about that. I would think it would have sounded like a blender full of marbles.
zf>allison
Apr 30, 2013
3,394
elsberry mo
Like I literally ordered a merchant return line thinking my stock one I extended failed, at most maybe thought the turbo had let go. But never would have guessed what actually happend
zf>allison
Apr 30, 2013
3,394
elsberry mo
Not only sounded ok but was smooth like no shaking. If i thought I dropped a valve no way would I have ran it to load it on a trailer. I was at work I could have pushed it on with a fork lift but I seen no point.
A. Stock Lbz
Aug 13, 2013
342
spokane wa
holy sh** man that is some carnage. you would think you would have heard that coming apart, crazy it ran and idled on the trailor! good luck on the build!
LBZ1991
Nov 21, 2014
215
Winfield, MO
I was there when we pulled it up on the trailer. It made a couple slight chunks. And sounded like it had a slight miss but not even close did it sound as bad as it is... :(
zf>allison
Apr 30, 2013
3,394
elsberry mo
It did crank slow and kind of hiccuped while cranking like kind of like the starter was weak. But we pulled it back to work with a strap and I had the key forward with the fass running the whole time and the battery light was on, so I figured that's why it struggled to crank. It did make one or two kind of like a slight thump. That's when I was thinking maybe the turbo blew and it was hitting the cover, but then I spun it and the wheel didnt hit. Then we got the turbo apart and found all my motor in there.
