What are you doing with the engine? Mild build? Or just repair what broke?
damn, I was thinking about your truck today. Odd that you decided to update!! Good luck with it all![]()
Is that a valve stem without a valve?
Yes i pried up the stem that's broke and it stayed up. So i imagine it's bent. And if u look farther back it looks like that valve is totally gone and that one, or another one got jammed up in the valve hole sideways. I pried on it also and it's jammed hard.
I imagine it will look kind of like this when you get the head off.
Believe it ir not this engine didnt have a single scratch in the bore! Going back together with a new piston and rings and head. 0_0Already planning on a new engine lol.
What pistons are those? Or is it just the picture that's making the bowl look distorted?
Probably not though![]()
Are you planning on just delipping your stock pistons or going with finger's?
Thats a 12 valve cummins.What pistons are those? Or is it just the picture that's making the bowl look distorted?
