Nope. It's not a DD and the front end is quite a bit lighter than a normal dmax
I didn't do anything to the top frame mounts and mines been fine. :thumb:
With your 6" front drop in your signature what else did you use other than the coil overs? Any one ever run these shocks without springs and with the torsion bars?
I have drop spindles. Why would someone want to run an expensive coilover with no spring? You could just buy a comparable shock if you want to keep the torsion bars.
The way the valving works on the Rancho's, adjustment only on the compression side, the rebound is too loose. The QA1 shocks have both compression and rebound adjusment but not heavy enough for a daily driver 2500HD truck from what I have read
The way the valving works on the Rancho's, adjustment only on the compression side, the rebound is too loose.The Rancho's adjustment is only for compression?
The way the valving works on the Rancho's, adjustment only on the compression side, the rebound is too loose.Before I installed the rears I worked them up down on the 1 and 9 setting, no change on the rebound that I could tell...The Rancho's adjustment is only for compression?
The way the valving works on the Rancho's, adjustment only on the compression side, the rebound is too loose. Before I installed the rears I worked them up down on the 1 and 9 setting, no change on the rebound that I could tell...
Well, driver side and passenger side jounce frame mounts are cut to make more room for the coils, split the spindles from the UCA, mocked everything up, upper adapters will be here tomorrow and will have the truck back on the ground hopefully. Gotta preload the springs and set the compression/rebound and go give it a test launch. Being able to control the rebound is going to help a lot.
If all goes well, bringing the trailer home and taking it to the track Friday night.
Awesome! Can't wait to see how they fit and perform.
gunna be a night and day difference when he dials them in![]()
Glad to see you're doing this to your pickup Brian.:thumb: One step closer to custom!!
I'm sure you're sick of James opening his whorish mouth about it!!!:roflmao:
Yellowchevy
Unfortunately install is easy, dialing in is what takes time.
hey you both like my whorish mouth! :rofl:
true for most but with where i want him to start with the shock settings from watching some of the fastest trucks around launch, i think hes gunna be close. its certainly going to stop front end lift his first time out![]()
Gee whiz a James, tell us more about your whorish mouth![]()
