The hangers are a real bitch. Don't let the c-notch worry you, it's easy to install and I've had mine on for 100000 miles without complaint.
Maybe I won't do the hangers then.. I had the over loads out before but it would hop like crazy when I got on it. Is there any other fix for that besides traction bars? Also I will need to do air bags in the rear because I tow my car with the truck. All this sounds like is more $$$$$. Stupid trucks!
BTW Hondarider, I love the way your LBZ sat
my duramax just became friends with the pavement
Should have the flip kit put on by next week and the 22s back on also
That drop on the front is 100% factory parts
I used 1500 lca 2500 bars and keys but had to swap bars left to right and flip 180 so they maintained the same torsional load and not twisting opposite direction. Cut off the jounce bracket to allow room for 1500 lca to swing and also you have to run 1500 shocks. Next project might be building an air setup on front that works with 4wd and doesn't involve mounting on the uca. Prolly won't as I find being low and static more appealing then bagged.
Yes it's 4wd and also truck has a 3.5" body drop and coil overs aren't out of the picture either and I Just like to be different that's why I try different options then the norm
Never seen a body dropped Dmax. wow, that's pretty cool! :thumb:
thanks guys and I so wish it was a shortbed
