I went with Viking shocks, they are made by QA1 and same quality. Brian this is the same equivalent as a the QA1 you have the link to, but alot better price.:thumb:
http://www.teambeefcakeracing.com/c209.html
I also ordered the spanner wrench and bearing kit for easy spring adjustment.
http://www.teambeefcakeracing.com/7995-102.html
Finally getting on team coilover![]()
Took a bit of time but I wanted to make sure I was not going to get any lower on ride height. Most have drop spindles and/or keys and I didn't want that low because I wouldn't be able to turn on the balloon tires.
There is a reason we went with the longer shock as well, no mistake there incase anyone is wondering
so whats a typical coil over cost?think I could still put a plow on my truck?
Is a 900# spring pretty standard for a dmax or does having a reg cab make it different for you.
...and that reason is?
I didn't want to loose but maybe 1-2" ground clearance from where im currently at right now (stock keys all the way down and no bolts)
CV's aren't level when I leave the line s wanted to get a max drop of 2" more to compensate, plus, I don't think I'd be able to turn on my balloon tires if it was any lower.
Removed everything today.
