Off to meet its new owner
F YEAH!Finally got to drive it, it's been 2 years since that has happen. Was like a kid in a candy store
I keep dropping the ball on sending you pics man I'll get to it hopefully tomorrow when the shop slows down
Great to hear can't wait for more :woott::thumb:I got everything pretty much buttoned up today!
MBRP turn down is on, factory fuel lines removed, replacement lines in, fuel return distribution block is plumbed, fan and shroud are on, cooling stack is in place, upper crossmember and core support at in, hot and cold side pipes are in, air cleaner is in, mishimoto rad hoses are on, engine mounts and grounds are tight all the electrical connections are plugged in...
I somehow or another snapped the tee on the drivers side return line off the #8 injector, but I got a brass tee to replace it...other than that
I just need pit the headlight assembly's and lights on and fill er up with fresh fluids, flush out the coolant system with distilled water and fill up with dex and I'll be on the road again!!!!!!!!!!
:thumb:
:woott:
Bet you'll miss that ol bucket
Thanks buddy here's a few more picsGreat to hear can't wait for more :woott::thumb:
Already do.. I want a 900 series body on a 455 chassis
Like so http://www.duramaxdiesels.com/forum/showthread.php?t=47063
That looks really really nice HOT_COCOAL :thumb:
I went from flares and body line down being plasti dipped to a nice clean truck. I think it looks better. I left the grill for now, but I think ill color match it at some point. Now all I need to do is adjust my front bumper and polish my headlights with the 3m kit. Oh and I cant decide if I should remove the badges or not.
That truck in the link you provided would be pretty cool, I've always wanted a tilting flatbed
:thumb:
Man that turned out really really good. How excited are you to drive her again. ill be pming you shortly about a few things Jason :thumb:
Truck loaded and off to Utah in the AM
Thanks BriLooks good! Nice job on the wrap :thumb:
Thank you!Thanks for posting more pictures Jason looking really good. I like how you have heat wrapped everything:thumb:then I look at the stock mouth piece with the resonator plug and I can't stop thinking perfect opportunity to brush up on my tig weldingI think you need a cool one off fabbed mouth piece
Sold it to Brennan I see!
