Nope not pump, checked easy stuff first. Passenger side manifold is leaking.
HeavyDuty204 New member May 26, 2014 127 0 0 Manitoba, CA Sep 25, 2014 #21 Nope not pump, checked easy stuff first. Passenger side manifold is leaking.
HeavyDuty204 New member May 26, 2014 127 0 0 Manitoba, CA Sep 26, 2014 #22 Apparently the manifold gasket isn't doing it's job. I'll get a new one on and it should be good. Thanks for all the help fella's!
NC-smokinlmm <<<Future tuna killer May 29, 2011 5,516 590 113 At Da Beach Sep 26, 2014 #23 You deleted the egr when you dd the pump right? How did you block off the egr riser? I'd bet if you used a plate that's the culprit...
L LB7LBZ New member Mar 23, 2014 2 0 0 Sep 28, 2014 #24 It sounds like the noise my truck made when the y-bridge o-ring blew out.
HeavyDuty204 New member May 26, 2014 127 0 0 Manitoba, CA Oct 1, 2014 #25 Well this was my problem... Attachments IMG_0014.jpg 96.5 KB · Views: 54
Cknight199 New member Aug 23, 2012 1,827 0 0 Salt Lake City, Utah Oct 1, 2014 #26 HeavyDuty204 said: Well this was my problem... Click to expand... Glad to see you got it sorted out
