1,517
Upper lower BJs and new pads
Installed my roll pan and cute little exhaust tip
De-badged and removed all the tape from the flares / molding on the bed. Then gave it a quick bath.
Before
After
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
bought a DP stg2 3794va today...
gawd DAAAAYYYYM it's about time, if everything gets here on time my truck will run again on Saturday morning:woott:
:spit:
it only took 8mo for me to replace my broken stock engine....
with a re-man stock engine :rofl:
:roflmao:
really tho, I got allot more than just the engine...just not enough to do what I want
1,517
Lift pump on my tow pig died.. Motor was only drawing .5-.6amps vs 4-5 amps.. Gutted the pump primmed the fuel system and rolled out.. 70.00 Jegs pump lasted ~75,000 miles
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
:spit:
:roflmao:
8 months, your fast... when you gonna put the cocoa puffs bird back in you avatar...:rolleyes: That commercial when I was a kid made me want to kick the TV and brings back a lot of ruff and tumble days that I'm paying for today...:D
Today hopefully work on the EGT gauge mount, need my manifolds back, hint Yellowchevy...:D
e46_330i
140
Youngsville, NC
I ordered the exact same setup!! That same grille, and a 30" bar.. Should be here soon hopefully
Nice! Had it sitting right on top of the trans cooler at first but had to move it in front of it and down a tad. Fits tight but it's there. About 1/2" away from the trans cooler and touches the grill on the sides. Perfect fit! Was going to try a 40" but a few leds would be covered on the side.
Akers
106
I dont do near as much as most of you guys but I finally got EFI Live for my LBZ. I went with the level 1 autocal from Kory and a dsp5 switch. I'm amazed at how much better my truck drives on his 100 horse tune vs the 100 horse tune on the edge evo I was using. It clicks right through the gears like butter now. With the edge it was a jerky ride. His tunes are also super clean which is what I was after. Even at WOT I won't get much more than a puff of smoke.
Now I just want to build the transmission and go faster!!
