If you're concerned about weight enough to pull the a/c out of a truck in Arizona, I would think the fuel cell weight would be pretty important too.
I lol'ed
Whats the difference in cell weight from a 10 gallon cell to a 20 in .100 thick aluminum? I bet the difference is me taking a poop before I head to the staging lanes![]()
I'm just giving you a hard time. The weight isn't much different if you don't fill up the 20 gallons when you race.
Lets talk rollover/vent valves, needed for NHRA
I have a -8 male fitting welded to top of the tank,
Can I use one of these?
http://www.jegs.com/i/RCI/821/7021A/10002/-1?parentProductId=
If I didn't have a welded in port, I know I would need the bulkhead style, but figured I would ask.
Haha, now we have a matching set. I did exactly the same thing.Went ahead and ordered that vent valve, thanks PA. Also ordered a K&N 1/2" air filter, and a -8an to 1/2" hose barb and that will complete the vent side of things. I think my air dog lines will reach all the way to the tank and back, being a regular cab and I mounted it under the bed on passenger side.
The vent on the right side of the tank, it's a rollover valve. If and when the truck goes upside down ball valve closes and seals tank vent. if tank was upright, it can breath normally through the air filter.
It will be just fine
The ball floats, so if fuel tried to come back up the vent, it shuts. when fuel drops back down, vent opens.
