what pins do I swap for af cam on lbz
THduramax
Will it ever end!
Aug 15, 2012
407
Flaherty, ky
everyone says swap a5 and b6 on the 24 pin harness.. the pic shoes I have a 3 row harness.. the pics they send me to show how to do it are 4 row..
xtremebikr04
Jan 17, 2011
573
Vermont
swap 2 and 5. Swap 7 and 6. Swap 8 and 3.
Only comes out to swapping like 3 wires. I just traced the wires back from the injectors. I forget what PIN numbers were.
Do you mean swap 2 and 5 with each other and just the power wire or all the wires on each respective injector?
xtremebikr04
Jan 17, 2011
573
Vermont
Sorry should have made this more clear. Swap the wires for injector 2 with the wires for injector 5, wires for injector 7 with wires for injector 6, wires for injector 8 with wires injector 3. In each injector pair you swap you're really only swapping one wire because the other wire is paired together.
I just went back and found my notes.
Injector 2 is
purple wire C6 on the big connector
Green/black wire A4 on the big connector
Injector 5 is
Black/white wire B7 on the big connector
Injector 7 is
Yellow wire C4 on the small connector
Red/Black wire B5 on the small connector
Injector 6 is
Yellow/Black A5 on the small connector
Injector 8 is
Pink wire C7 on the big connector
Blue/White A5 on the big connector
Injector 3 is
Green/Black A4 on the big connector
Hope this helps.
THduramax
Will it ever end!
Aug 15, 2012
407
Flaherty, ky
we are trying to swap pins on my truck to run the af firing order... diagrams show the connection having 4 rows of pins.. mine only has 3 rows.. 06 lbz.. any idea which pins we swap to get this during order right.. here's my connection
THduramax
Will it ever end!
Aug 15, 2012
407
Flaherty, ky
the way I was told is ya only gotta change a few pins to make it wurk.. the diagram we were sent had 4 rows of pins. mine has 3.. that's what I was confused about
xtremebikr04
Jan 17, 2011
573
Vermont
You have to change two pins on the small bail connector which you have pictured. Then you need to change 4 pins on the large bail connector. If you look on the backside of the connector you will see labeling molding into it saying what pins are what. The link I posted also shows what pins are what. I'm not sure if it makes a difference but mine was a SoCal alt firing.
THduramax
Will it ever end!
Aug 15, 2012
407
Flaherty, ky
yeah that's what mine is.. on the connector I have pictured we did swap two pins.. we had to cut them because one end was small and the other was big.. I can't remember which ones it was... but the thing that's got us thrower is in the diagram that guy sent the connector shows 4 rows of pins in the lbz... mine has 3 rows... so that threw us off
xtremebikr04
Jan 17, 2011
573
Vermont
I didn't have to cut any of mine. The large bail connector has 4 rows.
THduramax
Will it ever end!
Aug 15, 2012
407
Flaherty, ky
yeah it has 38 something pins.. the diagram sent said like 24 pins... we sent this pic I posted and they said that lbz's are 4 row... F!
