CP Carrillo Pistons
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
Just saw that someone let the cat out of the bag that carrillo was sending out pistons to test, anyone heard of anything? Didn't get a good look at them so i couldn't tell if the bowl was an oval or not.
Dirtymaxx03
3,109
Not an oval bowl. Dimitri was boasting on Facebook about a set they sent him to test. The picture looked like a normal bowl, gold colored coating on top I think?
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
I was wondering why cp didn't have any pistons out yet...considering they supply probably the #1 set of rods for a duramax.
quadracer37
Mar 31, 2009
547
northern, IL
We have a truck that's been running them for a whole season pulling. They are a test set, un sure if they differ from what will be offered to the public or not.
P
Piston Seller
Guest
Cp carrillo diesel pistons now in stock!
CP-CARRILLO INTRODUCES HIGH-PERFORMANCE DIESEL PISTONS FOR DURAMAX APPLICATIONS!​
Irvine, CA— CP-Carrillo is excited to introduce diesel pistons for Duramax applications. These pistons include the advanced features and improvements that CP-Carrillo has developed through rigorous testing and R&D. They are ready for IMMEDIATE delivery and are for the most popular Duramax applications. Join the winning race teams that have chosen CP-Carrillo Pistons and Rods, and get them off the shelf!
BUILT TO LAST
Manufactured from 2618 T-61 alloy for structural support and durability, these pistons come completely hard Anodized to withstand turbocharging, supercharging and nitrous.
DROP IN READY
CP-Carrillo’s Duramax pistons are ready to drop in to an engine, and should improve horsepower and durability out of the box and will be available on the shelf.
TECHNICAL ELEMENTS
Pistons features include a tapered pin boss to fit factory and aftermarket rods, .070 deep valve reliefs, radius bowl shape, 2mm steel gas nitride top ring, 2mm second ring, and 3mm 2 piece oil ring and Heavy duty .285 wall cold extruded chromoly wrist pins. Pistons are available in std , .020, .040 overbore in both 15 and 16 to 1 compression ratios. After a year and a half of R&D the pistons have been torture tested and withstood 1800+ Hp at the tires.
Part numbers:​
#D7000 4.055 1.946 15.1 Comp
#D7001 4.055 1.946 16.1 Comp
#D7010 4.075 1.936 15.1 Comp
#D7011 4.075 1.936 16.1 Comp
#D7020 4.075 1.946 15.1 Comp
#D7021 4.075 1.946 16.1 Comp
#D7022 4.095 1.946 16.1 Comp
56taskforce
1,096
80
What is the valve relief on a stock piston? Wonder if they will be offered as unfinished for custom applications.
