I know the 100% correct thing to do here would be just pull every piston, and replace rings and rod bearings. Probably adding about $500 to the project. My problem with that now would be (other than the $500), is that I've already torqued the Passenger Head on to the ARP studs, not realizing this would progress this far. If I pull that head back off, for sure I'd have to replace that head gasket.
Would y'all re-use those ARP studs? They were properly torqued with the ARP lube, but they did get stretched. Just the motor never ran and heated.
I'm still leaning towards slapping this thing back together after the quick deglaze and re-ring of the D-1 piston. All the other cylinder walls looked perfect. Not sure why this one piston broke an oiler ring.
Can I slap that single rod bearing back in used? Or replace it? Not worried about the cost of a single bearing, more just what would be better for the engine.
Does anyone sell a single piston ring set? I usually only see full sets.
I wish I'd started this project with a full rebuild in mind. Grrrr....
Jim
