How do u prevent the check ball from letting fuel past? I haven't drove it really since I replaced them, did some just regular driving and didn't seep any, but did very little under wot. But like I said I haven't played with it since then
lly does not have cups. to the op, it sounds like you are pushing fuel past the check ball, the only fuel in or out of the injector is from the hard line on the side, the return line out of the top, or obviously into the cylinder. it is highly unlikely that it is being blown back out of the cylinder, past the copper washer, and past the oring seal. if it looks like it is coming back up through the hole, it is most likely that check ball because rail pressure is too high
How high are you running your rail pressure? There has been a few LLY injectors that leak fuel out of the body under high rail pressure. Make sure your rail pressure sensor is rescaled if you are running over 180 for rail pressure. Other wise once it hits 180 it will just keep climbing and make them leak.
Well over this past winter I built my block. Added dual pumps, had my tips cut, charger etc etc. all the valve covers were powder coated. All mating surfaces were sanded down to ensure the injectors were sitting down in the bore far enough. Swapped the oem injector hold down bolts out to a harder grade and are getting torqued at 35ftlb vs the stock 22lb or whatever it was. When u really beat down on it the injectors still seep fuel out. This is only on my 600hp tune, not any of my big ones which would really pour prolly. Idk wat else could be the issue unless the oem hold Down retainers are flexing and letting the injector raise under high pressure. Are most of u guys with built motors/dual fuelers etc running billet tie downs or the existing oem ones? I've done everything I can think of and still to no avail..
They are just my factory hold downs that came on the lly. Idk if people are running them or replacing them with stronger, but I know mine keep leaking under wot. I just looked up socals retainer kit, $650 bucksdidn't see that one coming. Lol they come with bolts also but are only torqued to 32lbs it says.
Where do i check that at and what should it look like?
Table B0203. At 4.53 volts you will see the stock table goes to 180 and stays flat from there on up. Set it so that 4.53 is 181, 4.69 is 188, 4.84 is 195, and 5.00 is 202. This will allow the ECM to be able to read past 180 MPA when you command it. Otherwise if you lift the limiters and such, it will go full bore once it hits 180 as it has no way to know if it goes past 180 since the rail pressure sensor scaling stops at 180.
The Ferm is correct, I have a thread I started about this last fall.
On this particular truck when he logs it from my knowledge it doesn't go above the commanded 185 pressures. I have not seen a log yet. That is just what I have been told. It should jump to 200 if that was correct since that is the limit for pressure. What am I missing?
thanks i will give it a shot from what i can remeber my v2 stops reading at 180mpa when out driving it i think have to check
