Head Gasket Job
Belldiver
Dec 11, 2013
53
Louisiana
Hi folks!
First couple posts here and I'm a bit new to diesel engines. I'm pulling the block on my father in-laws '04 GMC 6.6 Duramax to replace the head gaskets and do any other basic stock upgrades that should be done at the same time. The truck has all the symptoms of a blown head gasket leaking compression gasses into the coolant system and I've also checked and verified with one of the liquid coolant/gas testers. Blue --->Green.
I keep reading about the ARP stud upgrade from stock head bolts and have a question about torque plate honing. I understand this is a step you might want to take with a new build/bare block, but is it necessary/required for just a basic HG job on a motor with 108K miles on it? This motor is not tuned, boosted, nothing...bone stock. It gets mild use most of the time, and twice yearly hauls a 32' 5th wheel trailer about 2500 miles and the driver does NOT have a heavy foot.
The lower end of this engine is still in great shape and I don't plan on pulling the pan unless I find some reason after the block is out.
I do plan on replacing the water pump at the same time just for good measure. Is there anything else I should consider while the block is out?
Thanks for any advice. ARP Studs, Water Pump. Injectors? Glow Plugs? Oil Cooler? Oil Pump?
Jim
ripmf666
15,123
14
49
Wentzville Mo
Have the heads checked and valve job done. No on the tq plate honing at that point you would be into a full overhaul. Pistons need to come out and you would be replacing torque to yield bolts and bearings.
jlawles2
1,126
66
Danbury, TX
Welcome to the site.
Since its your first time working on a Duramax, I suggest the Haynes techbook specific to the Duramax. Haynes number 10331.
I got mine from Summit, but several vendors here may have it.
Good luck on the job. Just did a bent rod in my Dmax and the techbook helps some.
I suggest taking lots of pictures of the wiring and hose locations.
Belldiver
Dec 11, 2013
53
Louisiana
I ordered that exact manual last week. Should be showing up any day now.
Definitely have plans on lots of pictures, plastic bags, coffee cans, and Sharpie markers. I've been through this before plenty of times with gas engines, this is just my first diesel.
I do need some advice on what to do with the injectors though. Any maintenance or cleaning I should do at 108K miles?
Thanks,
Jim
Belldiver
Dec 11, 2013
53
Louisiana
It's a 2004 GMC 2500 HD, 6.6 liter. I assumed it was a LB7? Could I be wrong here? I don't honestly know right now and I am currently offshore on a ship in the Gulf of Mexico. I could probably get somebody at home to take a picture or get me the VIN number.
Thanks,
Jim
993
They changed mid year from the LB7 to the LLY. It could be either one. The 8th digit of the VIN will be a 1 for the LB7 and a 2 for the LLY.
pullsanything
Enthusiast
Oct 7, 2013
78
Iowa
Any thoughts on the injectors? Preventative maintenance?
This will depend on if LB7 or LLY. Still, it is important to keep the injectors and feed lines as clean as possible to prevent contamination. Other than that good filtering is about the best you can do as far as preventative measures.
duramatt05
Nov 21, 2010
179
sunderland, Ont
I've done a couple llys and I just clean the carbon off the tips put new copper washers on. I would suggest if u havnt already, buy a headgasket replacement kit from merchant or creatures of the night. Comes with everything you will need to do the job.
pullsanything
Enthusiast
Oct 7, 2013
78
Iowa
The major diffs are LLY and newer have a variable geometry turbo and the injectors are accessible outside the valve covers where the LB7's are not.
993
No injector pulled required. I can't think of any specialty tools you'll need to do head gaskets.
