truck towing pictures...
1,517
I have 65 in the rear tires, guess I better bump them up next time
We rent the track at Atco for the day, $200 per person gets you a prepped track from 9am to 5pm.
My car is the blue one, got two shakedown passes which net me a 11.5@138 and then an aborted third pass, and final pass snapped all the flexplate to converter bolts. :mad:
Black one is a friend who ran the event, think he was doing 10.7s@132 area.
basic rule of thumb is trailer tires always run max cold psi.. under inflation is #1 for tire failure more so with trailer tires than any other types.....
on the truck i have the rear tires max cold psi as well helps side too side sway control..
sucks about the flexplate bolts
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
40
Kansas when I am home
Adam your kidneys must be bruised and beatin... I just can't run max cold in the trucks rear. I ride horrible enough even loaded with 65 in them I can't imagine going higher thane that. I also have to deal with mud roads and fields and max inflation isn't gonna help my 2 wheeler stay movin.
1,517
the 99 would beat the shit out of you on rough roads!! 56" long springs with 10000lb capacity! DD rear axle weights 2800lb :eek: skips very wells:eek:
slightes bump would lock the seat belt up..
07 rear weighs 2500 no trailer rides alot better less springs capacity and long 64" version..
pin on the trailer weights 1700lbs.. also when DDing the there is ~4" between the upper spring pack and mounts
1,517
indy than derby in then back to scotsburg in to load again
Big Block 88
Nov 3, 2008
4,665
40
Old school time, heaviest I have ever hauled on a 3/4 ton. Loaded trucks weight box full of parts all tanks full, 32k plus 7k trailer. On a race tune and stock trans
Big Block 88
Nov 3, 2008
4,665
40
2000 on hills. I was overseas when that truck got hauled, that would be why it had to pull with the big tune in. It survived and dad said the truck hauling the other one couldn't keep up. I had told him if a piston cracked or trans gave up it would be on him.
02greysixer
1,829
North Central FL
Every 6.0 powerchoke winds up getting a ride sooner or later!
(I know this is to much truck for this trailer and too tongue heavy but it was dead on the side of the road and we weren't going to pay a tow truck to bring it just a few miles to the shop)
Sent from my SAMSUNG-SGH-I337 using Tapatalk
blackdurkamax
Nov 9, 2013
this is what i do when my duramax is broken. its not much fun.
1,517
parked the truck and trailer friday.. :(
go to orientation tomorrow at 9 am along with a piss test... with the company i left march 2012... they (company) are very eager to have me back in a truck again
lts1ow
Needs moar PAH!
May 14, 2012
1,598
NJ
Gonna be picking up a new tire machine this weekend down in DE, prob bout 800lbs in the bed. Any issue leaving the big tune on and just driving not in tow/haul?
