truck towing pictures...
1,458
Here's what u did man, new shoes on. It rides 10 times better very impressed
I will see how they tow tomorrow have 25k pounds in panel fence to pick up
attachment.php
attachment.php
attachment.php
looks good man!!
BTW does your dual touch while loaded?
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
39
Kansas when I am home
I will get pick loaded I only had about 4k in the bed today I still had an inch and half between them. The tires have very square shoulders so they don't balloon out on the side walls like the wranglers did
Big Block 88
Nov 3, 2008
4,665
39
I can space them if there's an issue, only reason I went 235 85 is I wanted the 3050 pound rating
Truck went to get aligned also, hard to find someone around here to align duallys, it was out pretty bad but went back to 0.00 so it handles much better
1,458
did you have 235s before? mine touch.. i dont know the the offset is different between 01-07 vs 07.5 and newer
Big Block 88
Nov 3, 2008
4,665
39
Had 215 before but they were like balloons in the side wall touched under load. I really don't think these will touch but we will see. If they do I have some 1/2 inch spacers I can run. I believe the factory studs are long enough
I'm pretty sure our wheels are the same, unless u have the optional 17's but I believe that was an 08 and up options
ikeG
Oughta Know Better
Apr 19, 2011
2,553
189
Western PA
www.facebook.com
235/85's will rub when loaded, I had to get 1/2" spacers. The studs are just barely long enough.
1,458
someone at general dynamics land division lima Ohio cant do multiplication 35 5'/12' 1/2" thick armor aluminum plate plus .19" 5'x12' 170lbs is not 11,000lbs! more like 16,000:mad:
lts1ow
Needs moar PAH!
May 14, 2012
1,598
NJ
Just a quick question for you guys, when towing say a friends car, on a different friends trailer... whose insurance would cover an accident etc?
1,458
insurance covering towing vehicle ie the truck pulling everything.. i know progressing can give coverage for X days to cover said trip if you are that worried about it...
in a commercal applications its call cargo insurance
1,458
i had the dealer so mine on a saturday for 50.00.. PO ran the front tires @ 60psi and wore the tire in a under-inflated pattern.. 80psi no issues
lts1ow
Needs moar PAH!
May 14, 2012
1,598
NJ
I am slightly worried, will be two cars and the trailer, and I am not a commercially tagged truck.
Can you give any more info on the increased coverage? I have progressive
1,458
i'd call them tell them im helping a buddy move next couple days and would like have insurance on the trailer and cargo.. and see what they say.. iirc with out it the tow vehicle insurance covers bout 1000.00 bucks for anything trailered
Big Block 88
Nov 3, 2008
4,665
39
Light day today and tomorrow skidder 1845 case and the ford mostly huge steel stalls and corals comings soon should be a good load
