01 2 wheel drive
68skylark455
Larry the "Stroker"
Aug 7, 2008
1,091
Texas
www.larrysperformancepalace.com
My son found an 01 and the guy said it was tapping/knocking with possible white smoke 2 years ago when they parked it. I know about the injectors and am more than capable of fixing anything on it. My question is because it's an 01 is it worth trying to get and fix. It's $2500 the reason I just work on them and not own one is I have always been afraid I couldn't afford it when it broke. I can get the whole set of injectors for $1600 from my son who works at the dealer and I have pistons, rods, heads and lots of other parts off Blackie which is an 04 just asking opinions because it's the 01
3,591
What kind of shape is the truck in overall? Would the truck be worth the $4100 to you when done? If so, go for it. An LB7 is an LB7 no matter the year.
Schwinn68
little gearhead
Jan 9, 2008
632
Minooka IL
What configuration? How many doors? Is it in good shape rust and dent wise? Interior clean? Base model or LS? I would scoop it probably without hesitation. Especially since you have the knowledge to fix it and have access to spare parts.
Pics please!
68skylark455
Larry the "Stroker"
Aug 7, 2008
1,091
Texas
Haven't got pics yet it's supposed to only have 127,000 on it. Starter is bad and the batteries were dead anyway. I have just seen several horror stories on 01's and just not sure. Hate to buy a money pit but then again if I can make it run the trans is worth more than I will pay for the truck if it's as good as they claim
68skylark455
Larry the "Stroker"
Aug 7, 2008
1,091
Texas
Sorry for slow response this is my first time actually using tap talk on my phone for more than just a short reply lol. It's a 01 red 4 door 2 wheel drive long bed. Black cloth interior in surprisingly good shape someone stole the PCM TCM and BCM so he got used ones from Cali and the wheels are FUGLY but I have the factory chrome ones for it with caps
68skylark455
Larry the "Stroker"
Aug 7, 2008
1,091
Texas
dmaxman06
May 25, 2011
493
morenci az
cool i would buy any dmax for cheap if i could because even if its got something wrong with it u can still part out the hole truck and more that make your money back
68skylark455
Larry the "Stroker"
Aug 7, 2008
1,091
Texas
Swapped in a borrowed starter charged the batteries and before I could say anything my son cranked it a few times got oil pressure and the damn thing fired right up-with 2 year old fuel still in it:mad: but it runs good and has this tapping sound that increases and decreases in tone on the pass side and it goes with a miss too so maybe a bent push rod/bad rocker that would be great has the white smoke and smell of unburned fuel so maybe:thumb:
68skylark455
Larry the "Stroker"
Aug 7, 2008
1,091
Texas
Ok. Number 3 was not hitting checked rates and it was 15.0 lol. Replaced it with new GM injector and now I can kill that cylinder and "feel" a change but the rate is still 15.0 and it sounds like a bad lifter high time knock. Doesn't sound like a bearing knock and it smokes like a train at idle any ideas? Bad piston? Next will do compression but it cranks over and fires smoothly it sound like it is going full fuel like when you leave the ground wire off a dual dueler setup
68skylark455
Larry the "Stroker"
Aug 7, 2008
1,091
Texas
Well I played with it some more last night and tried to "clear" it out a little. The tapping sound started to go away and then come back lightly then louder then go away again, also noted at 1400-1800 rpm when the tapping goes away the whole thing "shudders" my guess is now going to be a broke crank :woott: the only thing I DONT have spare it seems:roflmao: I have pistons, rods, pushrods, gaskets, heads, flywheel/flexplate, balancer, glow plugs you name it I have a spare except for a crank! Maybe I am wrong but it acts and sounds like Blackie did minus the front part walking around wiping out the front seal and all that haha. Oh well, I will keep you informed, everyone have Merry Christmas and a safe New Year!!
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
I have seen the cranks break at the back. They don't always break up front like most have posted.....
Sent from my SCH-I535 using Tapatalk 2
