truck towing pictures...
1,517
Your going to be spoiled with the "new" truck hooked to the trailer.
I sent you a pm the other day as well.
sorry been busy..
for the short answer to your question.. i have ~20,000 invested in start up, truck, trailer, tarps, chains, straps, saftey equipment etc, and i leased on to a guy that was already well established record wise both safety and a vast amount of brokers
Mark13
I'm so much cooler online
Dec 6, 2010
31
Northern, IL
sorry been busy..
for the short answer to your question.. i have ~20,000 invested in start up, truck, trailer, tarps, chains, straps, safety equipment etc, and i leased on to a guy that was already well established record wise both safety and a vast amount of brokers
No problem. I know sometimes on various sites it won't show I have a pm unless I actually check under my name. If you want to reply back to it with more info when you have time that's fine. No rush on my end.
I've got everything besides tarps, you've got me beat as far as capacity of the truck goes.
matt78
Finally boosted launches
Sep 10, 2012
924
texas
I get a little when I pull, if the rpm has been up. Just a slight haze at the pcv reroute tube.
1,517
i dont see anything at idle out the pcv reroute tubes.. every now and then ill catch blue smoke at start up out the exhaust.. when i pull off after a hard run the end of the reroute tubes will be wet with oil..
DURAMXD
BOB SAGET!
Apr 24, 2012
348
Wichita, KS
been on the fence for a while now bout one.. found one 07 ls lmm 4x4 its ~300lbs lighter then the current truck.. biggest selling point is the 20-40% mpg increase over current setup
Nooooooooooo. I loved the old truck.
Congrats though, the new one looks nice too. Standard cab dually :thumb:
SmokeShow
6,818
Lawrenceburg, KY
LOVE the new truck. Definitely my favorite GM color! And theres always been that tough ass look with a reg. cab dually. Just screams tough to me. :thumb:
1,517
no new drivers will be added...the 99 is more truck than the 07 is when comparine suspension frame and brakes
