truck towing pictures...
1,457
heading to albany GA tomorrow
and this be the second one i have hauled south...
crbonline
Jul 10, 2013
17
Here's the toy hauler I drag around all year all over the place...13.5k dry, 18.5k loaded (trailer weight only).
crbonline
Jul 10, 2013
17
What kind of mpg do you see towing that toy hauler?
One average around 10...as low as 6 pulling grades with the foot into it and 11-12 cruising flat grounds...but I normally run with OD locked out which always shaves a few mpgs due to higher rpms but overall better for tranny and motor. I'm in cali and the trailer speed limit is 55...freakin nanny state! Pulling through nevada fully loaded (18.5k) doing 75 i get a little better mpg...the momentum helps with the load i guess. Cruising at 65 with no trailer I see 21-23 mpg. It's a heavy sucker and pulls a lot of wind drag.
bmemmott
33
Camarillo, CA
Here's a few from my old 02 with a Hodges bed. ImageUploadedByTapatalk1374367727.762387.jpg
ImageUploadedByTapatalk1374367841.491028.jpgImageUploadedByTapatalk1374367869.891227.jpg
bmemmott
33
Camarillo, CA
That truck also rescued my other truck a couple of times.
1,457
florence to scot la
picked up both of these around the layfayete LA area...two stop... macomb IL and milwalke wi
ended up getting drug out backward by a JD 200C.. it pored for 45 minutes (couldnt see behing the ford)
