How hot does everything get being that close together?
What do you mean? EGT's? Under Hood Temps? With everything being that close its all isolated. Your heat is better contained charger to charger on the hot side, which allows for better response of the low pressure. Plus you’re not running 3' of "hot" piping across the engine bay to raise temps under the hood. It’s literally two chargers with the same under hood characteristics as one, and the EGT management of two.
Caleb
