Here's a temporary pic of mine. I ll be picking it up from the alignment shop today.![]()
Yes sir BIGFOOT HDsAre those centerline wheels?
Sent from my PC36100 using Tapatalk 2
That looks good! :thumb:, Anyone got a pic of their lowered truck towing a decent load (skidsteer or something similar)? Then I will quit worrying and do it already
I put 3" drop shackles on mine and dropped the t-bars and it tows great. Seems to be more stable through the curves I guess from the lower center of gravity?
Not very heavy, 10k trailer and load together.What kind of weight? When I had that same drop mine didn't like it so much, front did ride way better from no pre-load on the torsion bars but I was basically on the bump stops out back.
i_keyser, what are the specs on your wheels and tires? Thanks.
those of you that are running the DJM 3/5 kit did you put your t-bar bolts back to stock or keep them down?
also what back spacing of rims do you need? would H2 or stock rims work? would like to keep the wheel well as full as possible, looks weird when you have small tires on these trucks I think
I took my bumps stops out.What kind of weight? When I had that same drop mine didn't like it so much, front did ride way better from no pre-load on the torsion bars but I was basically on the bump stops out back.
Here are a few pics, the top just bolts into the frame once you drill two holes, then a hole-saw to cut a notch to clear the air fitting. I would have to see about having more made. Jon didn't seem to want to, but i have the templets and could probably get some fabed up once i get moved to Tyler next month.
