GMC_2002_Dmax
The Still Master
I have a question for those that tow heavy loads.
Hypothetically if you had the following tow vehicle what would be your expected fuel mileage under this scenario.
Kodiak Topkick 4500 running the LLY/LBZ motor, empty weight is 12,500 lbs, gears swapped to 3:73 and tows in high elevations at speeds between 65-75 mph.
Average trailer weight is 6000-10000 lbs, weights go as high as 12K for towing with a gross of 24K lbs.
How much will winter vs summer diesel affect fuel mileage ?
How much will 10-15 degree temps affect fuel mileage ?
How much will high elevation affect fuel mileage ?
How much will headwinds affect fuel mileage ?
Thanks
Thanks
