Also, cylinder pressures are higher at lower rpms which is more strain on the rods. Higher rpms at the same power will have lower pressure and momentum in it's favor.
Boy, this is a can of worms you all opened up, lol. Since Banks was brought up and he holds the fastest Dmax powered vehicle then he makes for a great example. They are making their power well above 4000rpms so tq is low but the HP is higher and they are going 7.17 in the quarter. Food for thought...
Thanks Mark. Makes sense now.
I wasn't trying to discredit Banks at all. Just wanted clarification. :hug:
When it comes to rod selection, which is more important: horsepower or rpm? Higher power levels increase the compressive force on the connecting rods while higher rpms increase the tensile strain on the rods. As it turns out, most rods don’t bend and fail on the compression stroke but are pulled apart at high rpm and break on the exhaust stroke. Consequently, rods need additional compression strength and stiffness to handle higher horsepower loads. But in hig- revving engines, increased tensile strength is an absolute must for the rods to survive at high rpm.
No, I am not an electric waterpump guy. Have customer's that had issues with them more so than factory setups because of flow and pressure(or lack there of). We pin the stock one and seems to work good and haven't had an issue in a long time. Welding them doesn't work good becuase of how the shaft is heat treated so pinning was the next logical step.
head issues? hot spots? I would like to see a 75gpm electrica 55gpm at idle combined with a stock pump a electric can bennifit by coooling at low rpm, however the stocker will reduce flow from resistance, (combined with a electric)
it will still build 32 psi though, however I don't know the volume at that pressure? with just electric?
regardless I agree they don't pump the volume...
is that volume needed though? GM seems to think so.. What is you thought??
The issue that I have seen with them is they want to vapor lock at rpm/high hp and start melting shit. Technically they need both and the only way to do it would be with two pumps with some sort of variable controller to increase the flow at rpm. When they get hot on the dyno just maintaining light load with two fans going full blast there is an issue. When it happens on multiple trucks then it is no longer an isulated issue with a single truck. That's what got my attention on them.
I agree on the separating the oil/coolant but for guys like me that drive them in the winter that becomes another issue for getting the temps up to operating temp. I have been stewing over this for some time now and will probably address it in the spring time.
I'm not putting you down or anything just presenting my opinion as you did.
In your analogy and question above about Truck A vs B, where B ascends the hill without downshifting, and A downshifts.
Truck B puts more strain on the rods, since it has to produce the same amount of power, in less strokes.
Its like lifting 100lbs onto a table all at once VS. doing 25lbs 4 times.
If your arms are weak they will fail lifting the 100lbs, but can handle 25lbs easily.
I'm glad you started talking about this in the open as you can watch things so much easier on the dyno. I'm going back to a modded stock pump. I need to discuss with you the best way to plumb that also. Nice to see guys posting some tech again in this thread. :thumb:
Yeah, I don't normal share alot of info due to the way most treated me before but it seems to have calmed down so here we are. I personally feel that it might be the reason your head failed this year, not enough cooling to put the heat out of the head under power.
What kind of head failure are you talking about?
The drama on here is worse than a bunch of little girls...:baby:
But if that's the game I guess I will play...
I too am very thankful of all your shared knowledge Mark, your the man buddy...![]()
I know. I was wondering the nature of the failure.jddaves head
