PHP:
Cracked a piston in spring. Never thought about how little wot time we have on these motors. This was a very basic build. Rods, cut stock pistons, valve springs and headstuds
Sorry to hear it... so what is the plan next time around?
PHP:
And this is why you should build a BBC gasser. :roflmao:
Who says compounds aren't a type of twin turbo?Dan...."slow twin turbo truck"?
.......Salesman should use proper terminology if you're gonna talk trash. Try slow COMPOUND turbo truck!
Is my 5200' elevation 113 MPH run good for an 11 at PPSealevel? Last I checked a stock GM bottom end and a full weight truck in the 11s ain't slow.
Twins are two babies who are carried during the same term. Have you never seen twins where one was a boy and the other was a girl? They are commonly called fraternal twins. They come from two separate eggs that are fertilized individually. Identical twins come from the same egg that splits.Are twins not two turbos that are the same size? Do human twins have the same DNA? Lets define the word Twin and go from there....
I agree 100% but that was not what this engine was built for...
Just a heads up these large twin kit are capable of OVER 1500RWHP+ that is just under 2000K at the crank.
Yes it does. I call all turbo setups with two turbos twins. There are three ways to do it that I know of, parallel, sequential, and compound.Fraternal twins= a big turbo and a small turbo? Does the word compound describe the physics of how the turbos work together?
What kind of Junk turbos and fueling are you going to get for 10k?:roflmao:
Just the two Garrett Ball bearing turbos used in this kit are $7000. This is not including the install kit, waste-gate, manifolds and up-pipes, coolant tank, inter-cooler and ++ :hello:
Ok let’s use the engine you listed as an example with retail pricing....
So.... Stage 2 engine $18,400 PLUS CORE
PPE Twin turbo package std Big kit $15,500.
This kit has a second waste-gate on it they are about $550.00 plus the fab work to install it, lets call it $700.00 total
So just right here we are at $34,600.
BUT WAIT! We still don't have any fuel to drive this beast, So.....
Dual Cp3 kit with second pump $2350.00
Custom Injectors/Tips (balanced, custom tips) $2500.00-$3000
Misc fittings, feed line kits, $100
Now we are at $39,800.
OPP's! Almost forgot the removal/install of all the parts on the engine (this engine is drop-in ready)
Custom down pipe (custom for each truck engine year) to exhaust (not hood stack like Dmitri's)
All fuel lines (Feeds, plug and Play) custom.
I am going to be very conservative on the labor (I was quoted 3.5-4 full days) as there is a lot of custom parts so this kit will drop in and these big kits usually do not keep the AC (not normally kept in a race app) This one does...
$1500-$2000 (it should be $2660+)
So I'm SURE i'm forgetting some stuff but this should get us close at $41,450. (Mackin, take you shoe’s off and use your toes if needed or just use a calculator)
This is not including the GOLD PLATING and World Record Status…. Like someone said be for that HAS to be worth 10K…….
Bingo!!! :thumb:
:hello:
Please show me how you came up with these numbers?
So are SLOW twin turbo trucks.....
New over 15K.....
:woott:
Jess, Not around here.....
maybe you should call Guy and complain then....![]()
Trents ultimate race turbo kit is 8k and is advertised at 1200 rwhp
I'm confused..........I have a little time spent on dyno's, not much time really........:hug:...........and average loss thru the drivetrain isn't 20% of you HP/TQ it's around 65HP/100TQ on a stock LB7, on my LBZ IIRC it made just about 290HP/525TQ on a SuperFlow so 65-70HP/125TQ as a drivetrain loss.
So your stating that your loss is 500HP thru the drivetrain ???
Just looking to get some clarification.
BTW............good luck with the sale
:thumb:
Couple things here just cause that is the price breakdown does not mean it is not ridiculous. Can u say overprice! Most of these parts r ridiculously overpriced. I understand research and development costs but when is enough enough
And on a different note. I sure hope this is not the first twin engine that Ppe did in the black dmax back in I think 2010. Cause I heard from a very reliable source that during testing it had a failure and im pretty sure parts were just swapped out rather than a complete tear down and inspection.i think that puts it at about scrap price in my book. And scrap is down right now
What is the reason for liquid cooled ball bearing turbos that can support 1500hp vs journal bearing turbos that can support 1500hp other than the price difference?
