Viberations at high speeds in 4wd with tuff country lift kit
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
41
I just went back to the stock shaft. Actually Both my trucks are running stock front driveshafts without an issue.
leehype
Drunk with a Jeep problem
Aug 16, 2012
There is a good chance the vibration is the U joints on the shaft. When at an angle, the U joint creates a movement in the driveshaft. The shaft must move forward and backward through out it's rotation. This causes a vibration at speed. A double cardan joint does not.
Here is a chart as well.
Here is a double cardan joint
The double cardan joint is in essence balenced, and does not change length through out it's movement.
However, as some have pointed out, the extra parts tend to make them more prone to breaking. My personal experice is different as the driveline angles I am forced to fight with are much more extreem on my Jeep. I have had great luck with driveshafts custom made by Tom Woods.
I don't have a great picture, but here is the best one I have...
And how about a show of stregnth... Was trying to climb some culverts, and the rear end had too much traction. I was in 4low, second gear on the red line, heard a pop. The components involved were the Tom Woods shaft, cromemolly D44 shafts, a rubicon carrier, and stock ring and pinion. I sheared the pinion off and broke the carrier.
8,236
only to a point at or above a certain degree does this backward and forward motion start to become so much that osilation starts and creates a vibration. if vibration happened at any slight angle, every HD out there would have vibration issues from the rear as they all use a single u-joint at the front and rear.
like i said before, the key issue is not the angle the driveshaft is put at. its the fact lift companys do not put the front diff pinion angle at a paralell angle to the t-case front output. this is why a double cardan works so well in our trucks. in that setup, you do not put any angle on the driveshaft where the single u-joint is, you let the double cardan take all the angle. if i didnt have to redesign my whole drop bracket from fabtech to change the pinion angle id do it so i could stop the vib without the addition of a double cardan driveshaft
leehype
Aug 16, 2012
It does happen, only not enough for people to notice. The angle must reach a certain threshold to cause the vibration. It has to do with harmonics, some vibrations can be absorbed by the driveline, shocks, transfercase and transmission mount. Then you have the slip yolks that only feed the vibration to the axle. Easy to cover up. For an example, go look at early 2000's jeep liberty's, in 2wd model. There is, in essence, a dumbbell mounted to the front of the axle. That less than 1 degree on driveshaft that was less than 2 feet long was enough to cause a BAD harmonic vibration. They fixed it by adding weight to the front of the axle.
There are other solutions as well. Running 2 double cardan joints would be your cheapest bet, and I think it would be the strongest.
Most lift companies don't change the pinion angle because that same angle will make matters even worse with different u joint angles. The other issue, it stems from how much work used to be involved in rotating the pinion angle on a front axle. I know 2 guys that I think could do it around me, and they don't own shops. That is a huge procedure that after people started lifting, they found they didn't feel like spending money on. The lift companied found they didn't have to change the pinion angles as no one seemed to care, and it saved money.
AHHH, U joints, the only discussion that tops religion. Everyone has their own viewpoint on it, and what they think is right. I don't know everything, I'm just trying to explain what I have come to know as fact.
8,236
:confused: thats what i said.
Its not hard to make the pinion angle correct when factory can get it right off the get go. Its like you said, they took the cheap route and now created a market for double cardan driveshafts when they can be avoided to begin with
Swisstyphoon
258
Ft. Lauderdale FL/Switzerland
A couple pics of the carnage
Thanks for warning me about this shaft! I think you saved me from bigger damage. I finished my driveshaft loop last Friday, went to the dragraces on Sunday, first run was fine, but when I was building boost at the line on my second run: boom :( the damn shaft snaped just like yours. Glad I had my safety loop installed.
Will post some pics later...
8,236
damn you would think those parts are chinese. its awefully sad our stock driveshafts hold up better even with the bad angles on the u-joints.
8,236
IMOP, id source a dodge or ford CV and mate it to the stock shaft. one day ill get mine done that way. then its all stock parts you know wont give issues.
sharpshooter
Jan 2, 2013
I'm bringing back an old thread. Has anyone found a cv style front driveshaft that has no vibration and that holds up to drag racing? Or is it safer just to run the stock style driveshaft with the vibrations?
