So you drove it and it works fine now?
Sent from my PC36100 using Tapatalk 2
To clear up a few things;
1. The first I heard of you was when you called last Monday, I returned that call within 5 minutes.
2. Jeremy was the builder and called with the order and paid using a CC in his name.
3. This is the last email I received from him so I didn't know there was an issue until your call and we had no record of who you were. So far so good with the latest tune smoke gets better I tried to lug it into reduced power but she didn't bitch! I'll let u know when I drive it more
Sent from my Verizon Wireless 4G LTE DROID
I'll refund the card I have on file, and be done with it. Jeremy sent me photos of the build, you have a very nice set-up and hopefully someone will get it running to it's potential.
Good luck.
You charged my Amex, someone from what I think was a Jacksonville phone number called for the payment. I'm not trying to argue or start anything I just want my truck right
Truck is not 100% running fine as it has a BARO code that sets it in reduced power mode. Via datalog the truck only changed .1 in Voltage and from 14.5 to 14.4 PSI. This should not be a near enough change to set a baro code, however, the baro is within the ECM. So my next request is to Swap in another LMM ecm, flash in the same tune and see if it codes. Also, via datalogs supplied by trey, the MAF looked a little whacky, they swapped in another sensor and said it fueled a little better down low and the datalog came up proper as well. I have not sent anything refined, but as of now our only code is a BARO code. I'm about to leave for Mexico on Wednesday so if they supply me something by then i will be glad to help. Trey has been great to work with.
We don't take amex and can't even process. The CC processed was a Visa and not in your name.
Kory, I think you are talking about another truck. Trey had a non-twin stock engine with a 4094 that he did that had similar issues. The OP's truck is a full built engine/twins/etc.
Still waiting on that refund Rob....
It posted the 27th and since I never heard anything else about it I figured nothing had been done, my fault for not checking before posting but I forgot which account it was even on.
Rob, I'll pay you $5000 to come tune the truck in person to throw no codes and run the way it's supposed to, since I'm such a pain in the ass. You can have your run at it in GA, SC, or NC just let me know where to get it, hell I'll even fly you in to augusta so I don't have to move the truck.
Let me know, since it's obviously such an easy fix it should be a pretty quick 5k for you...
