LMM Stock Bottom End Limits
PACougar
2,105
El Dorado Hills, Ca
My buddy's getting a 08 LMM and starting in the winter we'll begin "modifying it". I'd like to know what you guys think a reasonable limit for a DD and a reasonable limit for the track would be? I'm not interested in what I should do to achieve the power, just in your experiences with LMM's what can they take without digging into the bottom end. Thanks for all of your help!
arneson
Aug 14, 2011
2,133
stoughton, wisconsin
Fronts whatever i have neen involved with, and talkin with people in tuning its more keepin the tq under 12-1250ftlbs. But many have 6-650hp, not sayin its goin to last a long time at that level. Its kinda like anything, some hold it for along time, others break at close to stock. Good Tuning helps a ton tho.
Bonestock
1,358
Worland Wy
I would agree with 650 being a number of reason. It will not last forever @ this level but has proven to many including myself that it will will last a while. A couple of dmax's in my area have lasted for 40,000 miles @ this level & still going strong.I really think the torque below 1200 plays a huge roll in this.:D
hondarider552
Getting faster
May 28, 2008
10,627
35
Arizona
With the known issues the LBZ/LMM's have with pistons, personally I wouldnt push it over 500rwhp and it will live just fine.
Harbin_22
3,858
Southern Indiana
Tuning and keeping EGT's and drive down are key in my opinion. Mine has handled a lot of abuse over the last couple years and the last couple months at 700+
PACougar
2,105
El Dorado Hills, Ca
Thanks guys, I'm thinking I'll set it up for 550 on the street and maybe 650-700 only at the track. As far as egt's go what appears to be the safe range for these LMM pistons, both as a peak and as a constant?
Bonestock
1,358
Worland Wy
The highest I have hit has been 1400 for short period of time. I have plenty of air just need more fuel but I am chicken!:eek:
Dirtymaxx03
3,109
600rwhp and 1200 ft lbs is about all you wanna push any dmax. After that its a toss up if your lbz/lmm is gonna have pistons for long or if your lb7/lly rods are gonna bend.
And i bury a 1600* gauge all the time
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
41
Houston, TX
I don't think the HP level is as much of a factor on LMM/LBZ pistons cracking, the heat is the biggest culprit.
It would be better to push 650hp at 1400deg than 500 at 1600+deg.
There are quite a few 700hp LBZ/LMM motors. The stock rods seem to hold pretty good. The pistons are like duck duck goose...you either have one that fails pretty quick or last a long time.
13,862
966
I cracked a piston in my truck when it was stock with twins. EGTs never got over 1350 after I put the twins on, and they had been on for over 10k miles when it cracked. I don't think EGTs are the problem.
Bonestock
1,358
Worland Wy
Now I have all the confidence in the world! Here come the dual c's! Lol!:thumb:
8,059
IMOP, heat, cylinder pressure, timing, pulse width, and strength of the piston all play a big part if you have a motor that will hold together at high HP. Guy once told me "if you have a lbz/lmm, run it at 600hp and enjoy it, if you have LB7/LLY run it at 500hp and enjoy it". Obviously, you need a tune built to help the reliablitly side of that HP you want but it dont garentee anything.
If you push it over what most run, you better subconciously tell yourself you will be building a motor or pullin the old one for another. You start flurting with high HP and all bets are off.
trailler2004
35
Guys...i read all this thread...am i crazy for doin 71.5 mm turbo...60 over exergys...dual pumps..manifolds and up pipes..vavle springs on my stock lmm bottom end and hoping it will survive 6-8 months til i can afford to build another shortblock??
