Off Season Sled Pulling Mods
rgullett83
1,607
Illinois
Well pullin season has started, but the last minute hooker is livin true to its name. Hopefully the shock relocation alleviates wheel hop, also installed 38 spline axles and spool from allseason, 4.56 gears, and a spool upfront, and duals in the rear, revised charger from ED. Still have a Precisision water to air to install also, but its on hold until we have more time ready to pull.
Sent from my MK16a using Tapatalk 2
CurtisEmery
Mar 21, 2008
486
Ontario, Canada
Well I finally got this thing track ready:woott: I went for a couple test passes this afternoon and all is well! The new much larger turbo spools great! 1st pass I let out of it at about the 200ft mark just to be safe and make sure everything was ok. My rail pressure was down 5000psi from desired. Pretty sure my lift pump is pooched. Gonna get a new one on monday. Second pass I went with a larger tune and rail was down 8000psi and then I blew an intercooler boot. I'm pretty pumped about how this front mount turbo works. I'm going to do a third gear start next hook to get my charger spooled a little better on the line. Here are the two videos from today!
1st hook:
http://www.youtube.com/watch?v=bASQ908THUE&feature=relmfu
2nd hook:
http://www.youtube.com/watch?v=a0Cs0Ug3hqE&feature=relmfu
RichLMM
699
North Kingstown RI
1st hook:
2nd hook:
:eek::hail:
95 z71
SUDDEN IMPACT
Aug 11, 2009
293
Cavan, Ontario
To Dave and Curtis, both trucks should put on an awesome show on friday.
Good luck and I wish I could be there to see the trucks in person.
