Just got back from my test with the 20K load up over Eisenhower tunnel. OHHHHHH MAN! What a trip. First time I've been able to keep it pinned to the floor most the trip and on ALL the grades (low power tow tune the whole time). The OATs were 77*F all the way to 56*F at the tunnel (11K elevation so what do you expect).
These were all recorded with the Fluidyne cooler and it's ducting, Schaeffer 9000 oil, and spraying the intake and cooler at 150psi with the chiller set at 15psi to activate (which was quite frequent and REALLY kept the EGTs and oil temps in check). It worked wonderfully!
At the C470 turn off (bottom of grades) oil temps were at 218*F
Genessee oil temps were at 235*F
East side of the tunnel, oil temp was 235*F as well.
I had a head wind most the way up of 20-25mph (pretty strong), and the water temp never budged from 195*F the entire time (so much for a bigger radiator fixing our problem).
I found I had consumed all the water from the tanks on the run up there so I refilled for the return trip. Now comes the big test. West side of the tunnel.
I was able to keep it pinned for about half way till the shear angle and alt robbed my power and speed. I had to shift to 3rd and hold it at about 60mph the rest of the way. Oil temps were at 246*F by the time I reached the tunnel. ECT was still at 195*F as was the trans that never wavered.
I run up another grade called Floyd Hill (short but steep) without the water to see what would happen. Oil temps climbed very quickly from 185*F at the bottom to 238*F and climbing FAST at the top. Interesting.
All in all,,,, I think the water spray kept things down more that I think they did. This test was NOT run with A/C on which I'm sure WILL drive those temps another 10-15*F higher min.
Makes me wonder about the temps without the cooler and set up I have now. It's scarrrrry to think for me.
Remember, I had a 20K total load today (truck included).
Tried to tell some folks over at "THE PLACE"
about these findings where there pushin a big radiator instead :rofl::roflmao: . One of them told me to go peddle my snake oil some place else. Some folks are so blind you cant even spell it out for them and continue to support and spread miss-info at all costs. This is very important to be relayed that a larger radiator will keep the TOP end of the motor cool. It WILL NOT cool the oil and everything that is being cooled and lubed inside. An oil temp gauge will tell you this right off the bat. This is why the gauge is important.
