Thought you guy/gals would enjoy some pics of Dmitri's New truck. We are building a new twin kit for it and a few other goodies...
Pics before we got started....
Sick pics dan!!!![]()
Can I ask why you guys chose to keep the rear shocks so much to the inside like that? Looks cool and all, but don't the wheels then have more than desired leverage over the suspension then?
My exact thought when I saw this pic a weeks ago. Looks like the setup on a tubbed drag car with a narrowed rear end, minus the narrowed rear end and tubs. I would have put the shocks much further out.
Who built the rear suspension?
really only comes in to play when cornering tim, when straight line racing the shock position from center will have little effect
I think it plays into straight line racing quite a bit with our trucks. all that torque transfers to leverage with our wide trackwidth and big tires. air pressure adjustments and shock dampening adjustments make a pretty big difference in how the truck launches. and that's with the shock in the stock location. now factor in how much harder the shock has to compensate when there is more leverage against it. it's a losing battle. our axles not only want to rotate on the axis of the pinion but also on the axis of the axle centerline. In order to keep everything rigid and controlled, I really think that the farther out the shock is from center, the more effective it is.
