When I got some free time, I will add a sensor to the other port. Getting bored watching fuel temps before and after cooler anyway.
That port is a 1/2" NPT threaded port. A plug for it can be had at any good hardware store. You can get them with a 1/4 NPT port in the center of it for the temp sensor, but if your sensor has a 1/8 NPT fitting (like mine), you will need a 1/4 NPT to 1/8 NPT adapter to screw into the bigger port plug to get it to fit.
I do like the killerbee coolers (you cant have to BIG of a cooler when running a thermostat), but my only concern is using the available space with air flow that we have. If I run a cooler the size of the radiator, but 75% of it is blocked from air flow, it doesn't do me any good. This is the exact reason why I'm going with the cheaper more cost effective twin cooler set up that will have 95% exposure to the air flow. If there not enough,,,,,well I will just have to back out of it slightly. However, I'm convinced it will be far better than the setups were running with no cooler at all.
Michael or anyone with aftermarket turbo/s that think oil temp is a problem have you done any UOAs? Stockish Dmaxs are pretty easy on oil. I've ran a dino oil up 15K before it started to shear. Thats better them most diesel pickups.
Trivia - I've run 3 engines that were primarily oil cooled (no water):
VW - Contrary to popular belief, the oil cooler does most the work.
Husky 510? desert bike. Not only oil-cooled, but no oil pump. Go figure.
Suzuki GSX1100G - Oil cooled monster bike. Stupid amounts of power everywhere from idle, manners of a Cadillac, and even handled pretty damn good.
That is all. You may resume your regular broadcast.
I did a report in the "oil temp with twins" thread and using stock power and unloaded truck. I didn't like my results. No UOA yet but working on getting some trucks tested. Are you running any oil bypass? I'm running my purifier and don't plan on changing it anytime soon. I'm going to have the samples run at every 25K intervals as long as I can on the same oil. Oil does NOT wear out if you filter it properly (it's been proven full flow oil filters don't cut it, and GM even did a study on this and found out there motors could last at least 7 times as long if filtered properly), it just deteriorates from over temps. What do we have to loose from cooling it properly in case it does get extremely heated (only takes once). Partial breakdown of the oil is issues I want to avoid as well.
I had an oil temp gauge well before the HTT was installed and EFILive was purchased.
With the stock turbo and Edge Juice it would easily put the oil temps above 260* while towing a medium sized load.
....and people wonder why LB7 injectors fail so often.Engine oil "cooking" them sure doesnt help.
