If you are looking for the best quality (components), Highest flowing/Most efficient design of Cast Manifolds/High flow stainless up-pipes on the market you need to check ours out.
1 year warranty on the parts. However if it's out of the warranty and there is a failure that is considered "defect in workmanship" they will be taken care of no matter how old they are. We stand behind all of our products 100%
I'm still running stock manifolds, up pipes, am inter cooler pipe. Gonna upgrade now. What brand and any suggestions ? Thanks guys
I think this statement might be a little bit of a reach.
How is it a reach?
Tell me Dan, will your up pipes and mine fit each others manifolds? In other words, are yours SO much like mine that the up pipes will interchange? Didn't you guys copy my up pipes directly so you could save some money even when you were selling my manifolds? Some day on a neutral site I'd like to talk about all this.
Yes our up pipes will work on the old style manifold and the new style. We already had the fixtures made. That was part of our agreement with you (before we started doing ANY business with you, which you approved). Don’t make it look like we stole your design.
If you want me to go into more details I can.....
O, and by the way...ATS had a set of their manifolds on display before I made mine and I never made any attempt to ( TEST ) theirs. As with most reputable manufactures, I tried to make mine totally different and STILL be better. How did/do you know yours are better unless you TEST them? Just by looks or.....
Well guess what... We did the testing and your design was lacking (not by much). You would have seen this had you tested them. so a better design came to market (materials , Flow, wall thickness, Layout).
As far as the looks of them... there is only a few way to make them look (ATS style/Yours/GM's). If you look at our design side by side with yours you will see there is a good bit that is different (internally and externally).
On a side note, how do I sign up to be a vendor over here? Pat will you have me? I know I've done some things you didn't like in the past although I had good reasons. I think my company has proved above and beyond that we are reputable and trustworthy.
Hmmm interesting, not to keep beating a dead horse, but i was told not once, but twice, i was pretty much $hit out of luck on 2 pedestals that cracked, one of them was on for just a little over a year, and the other was on for around 8 months, but had less than 1k miles on it. I mustve talked to the wrong person, even though im 99.9% sure it was you both times. The welds clearly had no penetration, my buddies pedestal that was purchased at the same time did the same thing, but his was on less than a year. Luckily i know a great welder, who fixed all of them, better than how they arrived out of the box. I know for a fact one of them is still going today, a few years later. I know shit happens here and there, but that was a very common problem, hopefully you guys have improved on that. If you have problems with pedestals coming apart, i can only imagine how the up pipes will do. Best quality componets??![]()
It's a reach because you don't have anything better quality then mine and I only gave you permission to copy my up pipes for my manifolds.
I have to disagree on this......
Ok I spoke to one of my engineers and one of Garrett’s. Our manifold design was not a copy of your design or LIMITED by your design. They were designed with from scratch to maximize flow using Garrett's proprietary fluid dynamic software.
The only thing that is the same as yours is the flange location for the up pipes. The reason we left that the same is so customers that would like to switch from the old style manifold (yours) can upgrade to the newest design and don’t have to buy new up pipes (the most expensive parts for us). The up pipe design has not changed (other than small tweaks to the Jig, along time ago, for better fitment) from the original sets we shipped out. We still use Aircraft grade bellows (better). We still use 1 pcs design on the up pipe tubes (better). We use a Hi-silica moly iron (Better).
I can get into the benefits of these "Better Quality Parts" if everyone wants.
You should have redesigned your up pipes to fit your manifolds not continued to use my design without my permission.
Again the reason we left this the same is so customers that would like to switch from the old style manifold (yours) can upgrade to the newest design and NOT have to buy new up pipes (the most expensive part to make).
You keep bragging about how much better your new design is so lets meet somewhere neutral and have a dyno test. Kennedy's comes to mind. We'll see whose makes more power.![]()
x2. Everyone else is second-best. Some (as Rob posted) are unabashed knock-offs.
Pro fab hands down
PPE has been dyno'g Dmaxes since folk were first starting to hotrod them.
No pissing contest but this matters how? Dynos don't mean shit & you know that.
