807 hp 1228 tq
xcablb7
Feb 8, 2009
536
Fall River
I'm thinking 11.1?? But will be very traction limited, slicks and some chassis tweaks should produce 10.80s but I'm not putting a roll bar in it so there's really no sense buying wheels and tires for one pass
Noreaster
2,910
Cape Cod,MA
I have a set proxes you can try if u want? IIRC a couple years ago bigbird ran 10.9x on proxes @ 7200lbs
What are ya running for a suspension setup in that?
xcablb7
Feb 8, 2009
536
Fall River
Djm drop shocks removed overload leaf, homemade traction bars, lowering shacklles and keys in the front, I might take you up on that since my dodge wheels are kinda heavy
bigbird
837
Edmonton, Alberta, Canada
Yep, proxes or equivalent tires, spring clamps and some decent shocks (i have rancho 9000's) and you'll be in the 1.60 60 ft. range which with your setup should let you touch a 10. saw you have traction bars so skip the clamps
tysmith
ZF-6
Aug 29, 2008
35
I think your tires are the fusible link right now... :woott: Get that thing to hook and that trans is on borrowed time. Life has not been easy for that poor girl!!!
