Will This Recipie Bring me 1000RWHP and 10's?
Rhall
Old Skooler
Aug 12, 2006
2,241
Texas Y'all
what type of hp was matt moon running if i recall he ran a 11.2 a while ago on his lift
Probably 800 id say, he just had a single charger on iirc.
Ive rode in an 800hp lifted truck, with the right lift kit, they launch just as straight as my truck does, not all lift kits are created equal though.
If thats the Twins you are already getting, then you will just have to work on the set up, if you really want it bad, they will get you 10's it might just take some work.
Colt
Jul 23, 2010
523
At 110 mph + I want to be low not up high wobbling around and lifting. Just my feeling but I hate a truck that feels squirrelly at that certain speed point that each has even on a good hard street race. Dropped Tbars and Caltracs feels like it is safer QA1 shocks adjusted to known place you want is a bonus instead of a shock not tuned. Just my take that's all. Run what you want that's why it's racing.
juddski88
Freedom Diesel
Jul 1, 2008
4,659
130
Chesterfield, Mass.
Robs right, the right lift will feel just as solid at speed as stock or lowered height. Tires play into it more than the geometry in this case I think too.
sweetdiesel
That's better
Aug 6, 2006
10,390
53
Thailand
Ken I thought of maddog when he first mentioned the lift
But that's not really a fair comparison
A 4" lift vs 6 plus is quite a bit different IMO
I think the front will be fine.with the right shocks
Do you have stock rear leafs? I think a deaver or something similar is a safer choice.
Many people in div 6 have lifted trucks and you see a lot of blocks and u bolts fubared
It can be done but it's going to take a lot of research and trial and error
I had good luck using air bags when I use to race my 05 but it was no 10 sec truck
Do you have the double knuckle shaft on the front. Shaft for your t case?
Either way good luck! But I can forsee alot of frustration and added cost jmho
Sep 10, 2008
1,072
Morehead City, North Carolina
When I build my motor I plan on keeping the cognito 4-6" ntbd kit. Simple enough to run 35's with rear blocks raised up or pull the blocks with t-bars out on 285's stock height. Launches perfectly fine. Only disadvantage is 200+ lbs I guess.
custom8726
2,784
Upstate N.Y
My first (And only clean) run down the 1/4 with my twins and 4" lift, I logged 132MPH and it felt stable and as safe as a stock height truck at speed. Granted its a 4" lift with the TB's all the way down but I dont for see it being to big of an issue other then the weight and aerodynamic disadvantages.. I still would not reccomend lifting or keeping a lift for a dedicated drag truck, but if your truck pulls double or tripple duty like mine, (Drags/Pulls/DD) I say run with it:thumb:
towboattrash34
Sep 30, 2010
212
Picayune, Ms
Who's lift ?
duramaxdiesel
Dmax Nut
Oct 23, 2008
1,378
49
Montreal, Canada
Thanks for all the advice and thoughts guys!
I retired this truck from work duty when I bought my Dually. It won't haul or tow anything anymore. It's just basically going to be my toy on the weekends with the family and to have fun at the drag strip every week. I know I'm going to break hard parts and such. I'm not running the knuckle drop kit. Didn't want to because I wanted to keep the same track width. But I do have blocks in the rear, and yes I've wrecked my U-bolts more than once lol. The Deaver spring pack sounds like a great idea. Thanks!
I will see where my turbo setup will get me. If I see that it's really running hot and can't meet my goal then that's when I'll sell the S480 and go bigger. I'm guessing I would be ok to keep the S366 in there?
Yeah I remember seeing Mad Dog's race with his Fummins. I'll be honest, it scared me seeing that. But my truck doesn't pull to the side at all. Granted, I only had a little over 500hp at the wheels and not 1000.
Other than tie rod sleeves, what else should I get to beef up the front end? I will need a TC brace now for sure. The build cost for the motor just blows my mind! And even after you have the motor and tranny you still need all sorts of little things to get the power to the ground lol. This sport really is a serious drug. I still remember putting my Edge Juice in the truck years ago and saying "I'll never need more than this" Yeah right!!
Nick
custom8726
2,784
Upstate N.Y
Nick
Strait center link solved my toe in issues, That combined with the Cognito Braces and HD tie rods makes a pretty stout front end IMO..
Subman
Old Geezer
Jun 27, 2008
3,233
10
81
Madras, OR, Pahrump NV
Agree on the super steer stuff, they make some awesome looking tierods as well. For sure on the centerlink, the heaver the better, there are several companies out there that make good ones.
My reference to Mad dog probably wasn't a good one, totally different beast and front end. My toy is a 10 sec truck and I want it as low as possible without dropping it. T-bars all the way down and passenger's side cranked back up three turns and then the front end realigned. Over loads off and I'll probably take out at least one leaf in the rear. It will not tow anymore either.
Brayden
Jan 16, 2008
1,170
www.fleeceperformance.com
Nick,
You should be able to hit 1000rwhp with that setup. We dyno'd an LB7 on 45pct sticks and 2400uS @ 845rwhp. (SSNARSKI's truck) Tony M has since turned the wick up and I'd venture to say it's at least 900 now.. He can chime in and vouch for it.. And the trans :)
There's no reason that a non gated 66/73 with a .91 or 1.01 housing and a billet S480 7 blade won't make a grand. We're making 927 on a single billet S475 on Tom & Joe Hill's LLY. The S480 alone will make 1000hp.
Your truck is a handful at 12.50 or whatever the last runs were at. Are you still going to drive the truck for your lawn care business?
Brayden
sparepartsracing
spareparts offroad&fab
Mar 17, 2010
773
35
totally different aspect to this but wasnt there a monster ford brand new on 40"s running really low recently posted on here launching really hard?
duramaxdiesel
Dmax Nut
Oct 23, 2008
1,378
49
Montreal, Canada
Brayden,
Yeah you sounded really confident with those two turbos you spec'd out;) The truck won't be used for work anymore. I bought a '01 LB7 3500 Dually. I bought it just before I blew the motor in my red truck. Best investment I've made so far!
I like the ideas I'm getting for the suspension and steering. Is an aftermarket intercooler going to be needed? And I have no idea what a fuel block is? Would I need one? I saw a few big HP guys with a sump on their fuel tanks.
I know that tuning is going to play a BIG part in all of this. If I do come to see you this time Brayden you can bet that I'm towing a spare truck with me lol. And I don't expect you to get it done in two days either. That I understand. I want this to all come together so bad I can taste it!
Again thanks for all the advice and info guys!:thumb:
Nick
Subman
Old Geezer
Jun 27, 2008
3,233
10
81
Nick I would for sure get an after market intercooler and I'd make damn sure it's reinforced on the ends and corners. I blew up a Spearco in White Out that they said would hold 100+ lbs of boost. And I wasn't making even close to that. Nathan reinforced the ends and corners by adding more through studs, and welding the ends.
Redbowties88
Sideways > Straight ;)
Aug 24, 2009
1,943
609 New Jersey
dude maybe you changed it since them or maybe im just crazy but i remember last seeing your runs at etown and that thing wasn't all that stable off the line
custom8726
2,784
Upstate N.Y
First time down the track with new twins, dual duelers, Tuning, etc.. Over boosted and hopped the front end across the track. I dont know of any front end that would look pretty in that scenario at 800+ RWHP. ;)
