New to Diesel Trucks
insaneABOT
Oct 13, 2010
Hey guys new to the forum. I bought a 2003 Duramax 6.6 turbo diesel but this thing puffs out white smoke I already checked the cooling system and no signs of water getting into the engine. The person I purchased it from told me that it needed injectors but I'm not sure on that. Different people have told me different things I had one guy tell me that the engine was toast and needed a new one had a another guy tell me that the tank had water in it so i bought something to clean it out the tank and nothing the truck still smokes white. I did a balance test but I'm not really sure on what I'm looking at here maybe you guys know what I pulled the dipstick out and looked at the oil and it is black I sniffed it and it smelled like diesel also the truck is throwing out a code iirc it is maf stuck in performance can that cause the truck to smoke white?
  • Duramax.zip
Kat
Wicked Witch of the West
Aug 2, 2006
17,900
20
62
Norco, CA
:hello: and :welcome5:
I can't open the file. I am guessing it's HP turners file? IIRC +4 indicates a bad injector. Someone correct me if I'm wrong.
Kat
Aug 2, 2006
17,900
20
62
Norco, CA
Actually I moved this to hard parts. Since more people will probably look at it there :thumb:
13,862
966
Does the truck smoke white at idle and clear up when you start driving, or does it smoke all the time? 9 times out of 10 what you're describing is injectors, especially on an LB7 truck. Fuel in the oil is an even bigger indicator of an injector problem.
13,862
966
I couldn't see it either, but yes, +/- 4 in park or neutral and +/- 6 in gear.
insaneABOT
Oct 13, 2010
this is what i get for all that is while I'm in park and sometimes they will all go to 0.0mm3 but only for a second then they go back to that
cyl 1 -7.0mm3
cyl 2 3.0mm3
cyl 3 4.3lmm3
cyl 4 -2.0mm3
cyl 5 5.8mm3
cyl 6 -1.9mm3
cyl 7 -0.2mm3
cyl 8 -1.8mm3
