do you have low oil? or is it your trans making that noise when its cold out? or low ps fluid?
relief hmmm? as in fluttering due to pressure? I would have to put in shims to avoid the flutter right? I can't do anymore pressure, part throttle hot is 90+ lbs.
Wish i had her running while you were here.. dammit Man!
Wassup with the minion gig?Inside "sheeple" joke?
Shims would create more pressure, orifice size may help or maybe a spring with a compression rate not so steep in relation to pressure increase to distance compressed.
Some of the guys a CompD were showing their colors. Called a few of us minions so we let them know we could care less what they said.![]()
Thanks Mike, sorry to hear about the CompD stuff, sucks. This vibration is the least of my issues at the moment....spent all day working on the master bathroom dead tired... parked the truck partially on the grass yesterday lawn Man coming Monday... started it up "ting ta ting ting"... like a little gremlin bird chirping in my brand new charger with less than 50 miles on it.RPM goes up "ting" gets faster, guess i am pulling the charger again. Shoulda sent it back when the comp wheel touched the housing while i fondled it fresh outta the box.
Who is the "BW Guru" of chargers?
I should convert to a blower!!
It's kinda odd how you had two turbos go, both with the chirp noises and of course the one tore up pretty bad. What kinda oil pressure are you getting to the turbo? Just wonder if you have a lack of oil to the thing?
