is there any mods that can be done to the stock turbo? other than buying a cheetah
is there any mods that can be done to the stock turbo? Other than buying a cheetah![]()
i-fog
What Jon fingers vanes ?
Garrett doesn't want a core back Dustin ??
what the hell is i-fog
Our original 71mm exducer turbine flowed better than the AVNT 69mm exducer that we use now but it holds up better. I have a 71mm and 73mm turbine built to try in a cheetah next.
For what it's worth, i like my Danville stage 2 in the MPI compound setup, though if he made something bigger on the exhaust side (which the Garrett 4094 AVNT is NOT) - something that flowed better, i'd take it. My turbo was supposed to have been brand new before danville worked on it - but i didn't inspect it close enough to know for sure whether it was or wasnt.
I think the hold up with my turbo and any of the AVNT isn't on the compressor side. Its on the exhaust side. Improve that flow and you've gained a ton IMO after all my 'testing' the past year. Still hoping something new hits the market very soon that improves on the exhaust side.
I'm sure you could do better, but all we may end up with is a re-badged set of twins from someone else...There is no cheap fix for mismatched twins, which is probably the case here.
i-fog
