How Much Diesel is Burnt at Idle?
THE-BEAST
Jan 18, 2009
Say you let your rig idle ofr an hour while in a restaurant - in traffic etc.
How much does it use in an hour?
Sorry if this is the wrong location - I don't see general discussions here???
Are there specific discussion areas for LLY, LBZ or LMM - if so don't see that either - easy to find on other Duramax forums....
:confused:
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
26
66
Norco CA
www.mcratracing.com
Let's see. 11mm3 vs. 33 @ 70mph, 20mpg, hr=3.5g/3 ...
About 1 gallon per hour would be my guess. I know I've idled 8 hrs before but don't remember exactly how much fuel, I'm thinking it sucked down a quarter tank.
5,101
703
More then that I think it was more like.7/hr. Ben (Duratothemax) post #s for his truck a long time ago on DP. I think it depends on the truck a bit too the LBZ/LMMs use more IIRC to help the truck warm up faster.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
26
66
Norco CA
www.mcratracing.com
I was was idling with the A/C full blast in 103F weather in Colorado at Bandimere. There was no shade for the kids, so they sat in the truck watching movies. Probably that consumes more.
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Not sure how much fuel exactly it will use, but I know it 0mpg..and thats bad...:spit:
Pat prolly explained it best. I am sure you can log it and get real close...
06WhiteLBZ
Diesel Addict
Don't mean to hijack the thread here but I've got a quick question...... what does IIRC mean??? I see it in a lot of posts and have never seen or understood what it stands for??? noob question I know....but you don't know if you don't ask ......
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,538
35
Lexington, Ky
AHHHHHHHHHH.........Thanks. Should have been able to figure that one out on my own.....but obviously didn't
Thanks.
Your not the only idiot, I have a hard time with the same thing.... Just go to google.com and type AFAIK means or FTW means etc. I have to do it alot too lol
But like Mike said it shouldn't be good, 0mpg isn't exactly considered very good fuel economy haha
06WhiteLBZ
Diesel Addict
For some reasone I never thought to try that on google ????? And I use google all the time. Hum....learn something new everyday I reckon.
And I agree....0 mpg tends to bring your overall average mpg down just a bit....ha.
FMOS
Hard Up
Nov 19, 2008
352
Fort McMurray, Alberta, Canada
Probably not as big as an issue with the DMAX's. I'm gonna say the advent of HPCR and fancy electronics and advanced injectors keep pretty good control of combustion in the cylinder.
The issue I feel would be greater, and is the same with a lot of motors especially diesels and especially larger displacements, is premature wear of bearings. Low speed idle is actually pretty hard on the bearings because there is more directional force applied versus when rotation is faster. Diesels are prone to it because of the higher compression and larger displacements are prone because of more rotating mass.
I've got my truck set to run on high idle most of the time. It eats quite a bit of fuel. I don't have any data to back up my claim... I've idled it for a longest of about 4 hours and that probably pulled 1/8th to 1/4 tank on high idle. Toasty Warm though! If its running, its usually driving a fairly long distance.
My old work truck was an 03 LB7. No high idle. It's idled/minimal low speed driving for about 200 hours during winter shutdowns. I'd say I was filling it up every 24 hours... 85 litres worth. It was quite good on fuel if you ask me. It was cresting 11000 hours and 60,000km when I left that position haha.
5,101
703
Its still a bad idea. Probably worse on the LMMs since they seen to have more fuel in the oil to start with thanks to the regen.
